Which bolts to use?
Old Jul 22, 2009 | 11:52 PM
IDriveALex's Avatar
Which bolts to use?
I am in the middle of an engine swap and I am also replacing my stock flywheel with an act streetlite and I was wondering which flywheel bolts I should use? The 6pd uses t55 torx screws while the auto use a normal screw with a larger head on it, but it is too short. I am having trouble getting my torx screws out so now I have to go out and buy some. Any part numbers or particular bolts to go out and buy?
thanks
Old Jul 27, 2009 | 05:31 PM
Nickk6's Avatar
You might want to check with dealer or place you bought your clutch. My exedy has longer flywheel bolts that replace the factory torx55 bolts. I would use either OEM bolts or the longer ones ONLY if required.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
doakley92
Sep 25, 2015 12:58 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
