Is my clutch going? 05 coupe
Old Oct 1, 2009 | 11:11 AM
COMMANDOE's Avatar
2005 G35 coupe 6spd 39k miles. My clutch has "play" i basically can press it about 2 inches freely before i fell it "catch". Works perfectly, no sticking between gears whatsoever. Is there any adjustment to this or is it beginning to wear?
thanks
Old Oct 1, 2009 | 12:06 PM
SPEC-01's Avatar
It sounds like you need to adjust your pedal (master cylinder, top and bottom triggers/pedal stop). This is a fairly easy process that can be found in the Factory Service Manual (I believe on page 15 in the MT section). If you want to give me a call I will be happy to talk you through this. Let me know. Thanks,
Old Oct 1, 2009 | 12:45 PM
COMMANDOE's Avatar
Great thanks alot!!!!
I will try and find it there first, if I can't figure it out I will call
Old Oct 1, 2009 | 12:48 PM
SPEC-01's Avatar
Good deal!
andrewvk
Interior
Aug 6, 2015 05:51 PM
TurboEE
Jul 31, 2015 10:41 AM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
vstypicals
Jul 20, 2015 10:55 PM
