Tranmission noise
Old Oct 17, 2009 | 04:13 PM
rootkit's Avatar
Angry Tranmission noise
hi all, i'm new with G35 forum. I bought used 2004 G35 sedan and everytime the tran switch from 1st shift to second - it makes a grind noise. But if i keep the car idle for 5 minutes startup - there will be no grind noise.
Does anyone know what's wrong?
Thanks much
Old Oct 17, 2009 | 04:18 PM
Neu Era's Avatar
Check transmission fluid level. Same happened in my 5at. Found out that the trans cooler hose was torn slightly.
Old Oct 17, 2009 | 04:21 PM
rootkit's Avatar
interesting. I will try that. Thanks bro
Old Oct 21, 2009 | 05:17 PM
rootkit's Avatar
yo bro. the transmission fluid is fine. It's in max level, both hose like brand new. It has to be something else...
Old Oct 21, 2009 | 05:27 PM
snotf's Avatar
sounds like your servos are going. how many miles are on the tranny?
Old Oct 21, 2009 | 05:29 PM
rootkit's Avatar
the car has 67k. I don't know about the tranny mileage. I'm sorry. What is servos?
Old Oct 21, 2009 | 05:40 PM
rootkit's Avatar
ah i just found out the servo means. how much do you think it cost to replace this bad boy? and do you think why might be the side effect if i just leave it alone?
thanks man..
Old Oct 21, 2009 | 05:42 PM
rootkit's Avatar
i just found out someone else talking about it's normal because ABS self test check before the car take off. Does it make sense?
Rizman
06/26/2009, 6:42PMI hear it once only. Some other forum indicates its to do with the ABS self test the car does when turned on and proceeding to drive.
Old Oct 21, 2009 | 06:11 PM
venom81's Avatar
Rizman
This is what I was going to suggest. With the ABS self test you should hear a sort of "clunk" when you first start driving.
If you're hearing this "grinding" noise after you've been driving for a bit and are pulling away after stopping at a light or something, then it's not the ABS self test.
Old Oct 21, 2009 | 06:40 PM
ttrank's Avatar
Grocery getter
If it happens "every time" you shift from 1st to 2nd it sounds like your synchro is going out. Pretty common on the 6MT's.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
