Diff oil: 75w-90 or 75w-140?
Yes. Manual says:
Oil grad and Viscosity:
Refer to MA-9, "RECOMMENDED FLUIDS
AND LUBRICANTS" .
Capacity:
R200, R200V
1.4 L (3 US pt, 2 - 1/2 lmp pt)
[/b]Drain plug and filler plug:
: 34.5 N·m (3.5 kg-m, 25 ft-lb)
I usually plan on two quarts (in case I spill), but it always starts spilling out the drain hole just past 1.5. I think what makes the difference is if you use a hand pump or try to cram the bottle up underneath. The drain hole is a pain to get to, and trying to "pour" into it will usually leave a bit of the quart bottle useless. . . if that makes any sense.
AND LUBRICANTS" .
Capacity:
R200, R200V
Cool thanks, my manual did not even have that listed in the Fluid capacity section :O
Thanks Willey
Drew and I have met before... he's a cool guy and I have no problem with him in general... I just don't respond well to derogatory posts directed at me.
If you notice, my jabs on this forum are 99% of the time responses to someone making a snide comment or derogatory post first... I rarely (if ever) make the first neg comment - but I definitely will respond to them.
Guys guys!
Beer's on me!
But seriously, just to clear it up: I was curious (and assume others would have the same question) what the difference is between the two oils. No need to read into it any more. . .sorry if my ramble was confusing.
And definitely, I know the grey ghost has a very inquisitive owner. Not sure I'm sold on the vortex ring
but I'm still lurking about reading up on things from time to time.
Beer's on me!
Guess the bandwagon approach isn't good enough? How about I make power all the way to redline.
Oh, and the 75w-140 would be ok but once it starts to heat up you'd probably feel sorta sluggish because of how thick it would get compared to the 90 weight.
Originally Posted by Tollboothwilley
You're not sold on the vortex ring - you talking about the TB spacer? What does it take you to be sold on it? I have one.
Meh. ..on second thot a TB spacer is probably the only mod I could easily afford right now. *Sadness*
Oh. . .and best thing ever. . .I called the place I bought it at and asked if I could exchange them for -90. They were cool with it even though it was over a year ago that I bought it and I didn't have a receipt. So. . .no more 75w-140 for me, EVAR! LOL
I have a 1 year old daughter now...changes everything. Not only is my wife not working now all the money seems to go towards her. My car budget gets neglected. haha
The throttle body spacer makes sense to me. In that 60* angle bend you know that air will slow down around the longer edge. The spacer redirects the air so that slow spots aren't developed.
Don't you think an improvement like that would have shown up on Hydrazine's dyno test?
Cool, it all worked out
BTW, I don't know how you guys are able to pay for kid(s) and still have a G and mod it... I drove a beater for 12 years while paying for my kid... but I was much younger and didn't make as much money
yes, Ams is quart - good looking out
http://www.amsoil.com/a/synthetic-gear-oil
In other vehicles, they come to the same conclusion though. Here's some research from jeepmagazine:
Jeep 4.0L Myth Busting - True Lies
4.0L Myth Busting
By Christian Hazel, Pete Trasborg
Over the years, Jeep's 4.0L engine underwent a few changes here and there, but nothing drastic. Despite the similarities, many still think of the '91-'95 XJs as the fastest six-cylinder-powered Jeeps in stock trim. For some reason, the '97-'01 XJs just don't feel as fast. Did they change the engine? Did OBD2 kill the 4.0L? Probably not, because if you drive a '91-'95 YJ or a '97-'06 TJ, there's no appreciable difference. The older XJs probably just feel faster because they have less sound deadening material and some other heavy components. At least we think that's the case. And with that, let the myth-spinning begin.
We've heard dozens of fish stories about how to make power with the venerable 4.0L Jeep engine, which parts are better, and which ones are wastes. Well, we've got around a half-million miles under our tires thanks to the trusty 4.0L Jeep inline-six. We've also got well over 100 dyno runs on these engines and have a good idea of what makes power, what improves drivability, and what wastes your money.
Jeep 4 Liter Engine Myth Busting Throttle Body Spacer
Myth: Adding a throttle body spacer will increase the intake plenum volume for more air and a higher velocity intake charge. Also, rifling an aluminum spacer helps air flow into cylinder head with less turbulence for more power.
Our Thoughts: Depending on the application, a spacer works wonders on a carbureted or a TBI-injected engine in which the air/fuel mixture atomizes and flows through a wet manifold, but results are less drastic on a MPI engine in which only air flows through the intake.
Claimed Gains: 10-15hp
Actual Gains: 0-3hp
Notes: With our Red and Mileage Master projects, the largest power increase we've seen on the dyno was 1hp.
Even the Toyota Tundra guys drastically shun them:
http://www.tundraheadquarters.com/bl...-body-spacers/
And, as I said. . .if Tony--the Flow Bench Master Guru--says they're not of any benefit, I give him the most weight in the VQ community. Bad enough for Tony, bad enough for me.
But, again, if you feel it works for you, and it makes you more power on the dyno, good.
Okay, so back on topic. My oil is all changed. I have 2 and a half more quarts of 75w-90 now. I'm happy.
no point in trying to convince of the TBS - as you probably know, I've gone in circles about it... buy I'm glad you concur (you are one of the more logical out here).
Originally Posted by Jeff92se
Tony was there observing the dyno test on Mike's car. Tony's conclusions aren't based on what he thinks. It's based on the dyno proof presented.
