differential oil change
Old Feb 5, 2010 | 06:22 PM
whoisthis's Avatar
im gonna change differential oil on my 06 g35 coupe. So i bought two mobile 1 75w-90 LS gear oil. Gear oil is same as differential oil, right?
What does LS stand for? These bottles look little different than other bottles. These are more slim and has this....funnel(?) looking cap.
did i get the right oil for my car??
Anyone know the torque for filling and draining plug?
thx
Old Feb 5, 2010 | 06:28 PM
CLEANBS's Avatar
yea you got the right oil, im not 100% but I thought I only needed 1 bottle when I changed mine
Old Feb 5, 2010 | 06:29 PM
Swivel's Avatar
Moderator
LS = Limited Slip? You'll need 2 - takes about 1.5 qts (3 pints)
Looks like it's GL-5 so I think it should be fine...AFAI can tell, it has no additives that our diffs should not have.
Anyone else?
Use a 10mm hex and torque to 25 lbs feet. Oh, and take the TOP one out first, that way if you get the bottom one out, drain the oil, and then can't get the top one out, you are less fornicated.
Old Feb 5, 2010 | 06:44 PM
whoisthis's Avatar
Anyone else?
it is gl-5. Gl-5 is only for gear oil?
Old Feb 5, 2010 | 06:56 PM
Swivel's Avatar
Moderator
That is an API gear lube standard, yes.
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
