5AT questions
Old Mar 5, 2010 | 07:36 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
5AT questions
2005 coupe with 32K miles. bought new and car is 4 years old from in service date. car is only driven regularly during spring, summer, fall. is it too early to have flush and fill...is it overkill?
side question if you know. when is a valve body upgrade necessary? was going to wait to have it done with Vortech install as car is only 260RWHP per last dyno.
thanks.
Old Mar 5, 2010 | 08:28 AM
rcdash's Avatar
It's never too early to change the fluid! A drain and fill is recommended yearly or flush every 2 yrs, for a stock car. I drain and fill every 6k miles (but that ends up being only twice a year at most for me).
VB upgrade helps to prevent clutch pack wear in high torque applications. You will want to get it before you drive the car with the Vortech.
Old Mar 5, 2010 | 08:55 AM
miltoda's Avatar
I drain and fill every 20-25k miles after the initial 30k. That ends up being about once a year for me.
Old Mar 5, 2010 | 10:16 AM
DRG35R's Avatar
20 Year Member
^^ thanks guys. I will do a flush and fill.
can wait for the VB when Vortech is installed.
Old Mar 5, 2010 | 10:18 AM
Tollboothwilley's Avatar
might as well do the VB now
flush/fill is good enough every 30K miles for normal driving
Old Mar 5, 2010 | 11:38 AM
DRG35R's Avatar
20 Year Member
yeah, I could do that prior to Vortech install when I have the $$.
30K is what I was thinking for my car.
Old Mar 5, 2010 | 01:32 PM
DRG35R's Avatar
20 Year Member
will I need any cleaners or conditioner additives or just the correct Nissan J-matic fluid?
Old Mar 5, 2010 | 06:22 PM
superchargedg's Avatar
Stop by my shop and you can see for yourself what the v/b mod does.....you have PM.
Old Mar 6, 2010 | 12:55 AM
mikek46's Avatar
Just hit 40k on my 06, pretty sure the 5AT fluid was never changed based on previous owner's service history (30k miles is the maintenance interval to change it). Will look into getting it done soon.
Shifts fine, except the 1-2 shift is a bit rough when the fluid is completely cold after sitting all night. Rough shift goes away after the first few 1-2 shifts. Is this normal or an indicator that I better hurry up and change the fluid?
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
