Is this possible?
Old Mar 11, 2010 | 11:32 AM
TheDude's Avatar
Is this possible?
Will a rev matching 2005+ 5AT transmission bolt up to a 2004 5AT?
Old Mar 11, 2010 | 12:00 PM
Jeff92se's Avatar
Red Card Crew
Bolt up? Probably? Work properly? Probably not. Depends how the ecu/tcm play with each other.
Old Mar 11, 2010 | 12:01 PM
I ride G's Avatar
hmm? i dont think the AT has rev matching...i think the 370z's came with rev matching and the 05+ 6mt's came with rev up motors.
i could be wrong though!
Old Mar 11, 2010 | 12:18 PM
DaveB's Avatar
In 05 the 5AT came with the rev match downshift feature. I've tried it with a few 05-06 loaners, but wasn't terribly impressed because it's a bit slow of a rev matched downshift. My 03 will manually downshift a lot quicker, but it can have a bit of jolt which isn't exactly ideal either.
To the OP, like Jeff said, it will most likely bolt-up, but after that it's not going to work unless you've got a 04.5 car. That could possibly work, but that's a pretty expensive gamble. I'm also not sure how the system works because there is throttle blipping occuring which means there's additional ECM/TCM control. I'd say if you want the rev match feature, sell your G and get a newer one.
Old Mar 12, 2010 | 12:11 AM
TheDude's Avatar
Hm, that sucks, oh well, my car is an 04.5 and I just bought a fully built tranny hopefully that will improve it. If not, I can live with it.
thanks fellas
