Changed Man trans fluid NOW have issues
Old Apr 24, 2010 | 10:50 PM
COMMANDOE's Avatar
Update!
Well after 436miles of royal purple full synthetic in my man transmisson. I just changed back to Nissan OEM man transmission fluid (9.36$ quart). And..... transmission returns to flawless fluid shifts! . I join the legions of G35 owners that swear by OEM and no other.......
Old Apr 24, 2010 | 11:00 PM
Shakuya88's Avatar
I have an 04 and switched to RP. I was having a couple issues before and the RP fixed the issues for about 2000 miles but same issues as before are back now. But no hard shifting, just my grinding into 5th (which was before RP swap also)
Old Apr 24, 2010 | 11:06 PM
COMMANDOE's Avatar
Thats interesting. As I said above I had absolutely 0 issues before I switched to RP., merely changed as a maintenance thing. And I immediately had touch time shifting between first and second.
Old Apr 25, 2010 | 09:37 PM
Shakuya88's Avatar
Being an 05 and having the 009 trans maybe that is why. I only have a 008 so that MAY have something to do with it. I'm updating soon to a 009 because of grinding 5th issues (going to dealer tomorrow, wish me luck!) after that in 60,000 I'll switch to RP again and see if any issues arise.
Old Apr 25, 2010 | 09:53 PM
Johnnyone's Avatar
I did mine last wk with oem with no issues and did my buddies today with oem but I almost went with RP, glad I didn't.
Did u change ur diff fluid to? Being that u are 42k might b a good ideas to change here soon. Don't think they have oem fluid for it though. When I went to the to the dealer they sd me pennzoil.
Old Apr 25, 2010 | 10:03 PM
the_sedan's Avatar
yeah they use pennzoil 80w-90 for gear oil for lsd diffs.
Old Apr 26, 2010 | 04:52 PM
Tollboothwilley's Avatar
I used Mobile1 for the rear diff with the VLSD
Old May 3, 2014 | 04:57 PM
justjon51's Avatar
no no no
i used royal purple in my g35 and shifting went bad in 5th gear..... car was perfect before i started useing royal purple. shift bad right off the bat i tried waiting for alittle seeing if it was just cause it needed to be circulated but then 2 days later my 5th gear started to hard to shift into
Old Mar 31, 2015 | 09:15 PM
akoustic's Avatar
Nissan MTF FTW
Hey guys,
I've done a few transmission fluid flushes and I've found the Nissan MTF 75w85 to work the best. I've used Motul 75w85 cl4 before for a while and that was good too. But please guys and gals, do not use cl5 or cl4/cl5 combination fluids because your transmission will start to make a lot of noise when it's cold (or even in chilly temps) . Not to mention very notchy and uncomfortable shifts when cold. After flushing out my cl4 Motul two months ago and refilling it with cl4/cl5 Motul 75w90, I immediately heard the infamous cold start "howling noise". The sound persisted to come back every cold start until fully warm. I've driven my g35 coupe for about 7 years and those was the most annoying drives. As soon as the temperature dipped below 10 Celsius you had the sound and notchy shifts at cold start. Horrible. Anyway fortunately I didn't drive much sine and today I switched the fluid to Nissan MTF 75w85 and the problem is gone. I'm sure I will get some howling noise when the temp goes below freezing but I guess I won't know until next year (and hopefully not until next year )
I was looking at Redline for a while but decided to go OEM and I think I made the right choice.
Anyways long story short stick with OEM or at least make sure to buy cl4 type fluid only. A quick search will show that I'm not the only one with similar results.
Ps. I'm using Motul diff fluid and it feels great!
Cheers!
Old Mar 31, 2015 | 09:26 PM
JHereth22's Avatar
Never thought I'd see a post where Jersey was informative. Jersey please do this more often
Old Mar 31, 2015 | 09:49 PM
Lartytiejdke3's Avatar
are you that dense?
Old Mar 31, 2015 | 09:51 PM
JHereth22's Avatar
are you that dense?
No, but I've never seen you do that post ^^
Just a statement
Old Mar 31, 2015 | 09:55 PM
No, but I've never seen you do that post ^^ Just a statement
that's not me
Old Mar 31, 2015 | 10:02 PM
JHereth22's Avatar
that's not me
After stalking your page Id like to apologize. You are very helpful to the community.
Old Mar 31, 2015 | 10:18 PM
  #30
Follow me on FB so I can verbally abuse you
