FS: Lightly Used ACT Streetlite Flywheel
Old Jun 9, 2010 | 12:28 AM
mx592's Avatar
I used this flywheel on my 6 psi TT G35 for about 1,000 miles. It was brand new when installed, and I was using a ClutchMasters FX300 kevlar clutch. Kevlar is very non-abrasive friction surface and because it was only used 1,000 miles there should be absolutely no need to resurface the flywheel (if you run your fingernail radially on the surface you can easily feel the original machining ridges). There are some discolored spots on the flywheel but I am not sure why - I never did any drag launches or really aggressive driving and I don't slip the clutch. There are no heat cracks or anything of that sort and it is not warped, it always had a nice smooth engagement.
Weight is 16.9 lbs.
Price is $300 shipped in the lower 48. Paypal add 3%.
Old Jun 9, 2010 | 03:26 AM
laksjd84's Avatar
hmm..why does it look liek its etched, or burned on the middle part?
Let me know if you are willing to work out a deal on this.
brand new is around $360.
Old Jun 9, 2010 | 12:47 PM
mx592's Avatar
Are you referring to the "burn marks" on the friction surface? They are caused by the heat generated by the pressure plate friction. I am not sure why they are only in certain spots. Like I said, there are no cracks and the surface is flat. I never slipped the clutch hard and I only had it on the car for ~1,000 miles. It was working perfectly when I removed it. It could have something to do with the kevlar clutch I was using.
Where can you buy a new one shipped for $360?
Make me an offer.
Old Jun 11, 2010 | 12:49 PM
mx592's Avatar
Bump
Old Jun 15, 2010 | 01:20 PM
mx592's Avatar
Bumpity bump
Old Jun 18, 2010 | 08:12 AM
mx592's Avatar
Sold!
11bEMT
May 27, 2022 03:13 PM
yosip1115
Aug 26, 2015 10:46 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
