weird grinding noise
Old Jun 27, 2010 | 04:44 PM
brianle12345's Avatar
i have an 06 mt... and everytime in 1st gear going to a full stop..as i push in the clutch in 1st to go into neutral... it makes a loud grinding noise...and also when i shift from 1st - 2nd .. it makes a loud grinding noise.. i tried shifting it slowly but that doesn't help. it happens about 90% of the time i drive... help ??
Old Jun 27, 2010 | 04:56 PM
CERBERUSlucid's Avatar
what RPM are you shifting at from 1st to 2nd???
Old Jun 27, 2010 | 08:24 PM
LMG_35C's Avatar
check fluid level, & color should be almost clear..clutch release - was it adjusted-maybe it's not releasing? have it checked soon
Old Jun 28, 2010 | 10:28 AM
Tollboothwilley's Avatar
check fluid color/level - flush if dirty
could be a bad syncro in the trans...happens a lot
Old Jun 28, 2010 | 06:26 PM
im shifting at 2.5 , and the fluid color is dirt brown, it wasnt adjusted though.
Old Jun 28, 2010 | 09:20 PM
LMG_35C's Avatar
dirt brown must go before the tranny heaves. be sure to drain, fill, short run, drain, fill, to get it clean. u don't say how many miles on fluid but could be anywhere from normal wear at 40k+ miles to you've been toasting it regularly for the fluid to be brown...
be sure to use good quality GL-4 type, 75W-90 fluid.
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
