Camshaft position sensor (location?)
Old Mar 18, 2014 | 10:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
Try replacing your crankshaft position sensor, that often goes around the time the cam sensors do.
Old Mar 18, 2014 | 02:02 PM
Glikeme's Avatar
Even if I'm not getting a fault for the crankshaft sensors,
replace them?
Old Mar 19, 2014 | 11:08 AM
Blue Dream's Avatar
There's only 1 and it will cause issues but not throw a code. Seen it happen on here a lot of times. Plus like I said in your other thread use OEM sensors, aftermarket are known to not play nice with the G's.
Old Mar 19, 2014 | 06:59 PM
Glikeme's Avatar
Alright thanks Blue Dream I'll give that a try and let you know the results of it. Is that an easy fix like the camshaft sensors or require more work. If I can I would like to do the work myself
Old Mar 20, 2014 | 10:52 AM
Blue Dream's Avatar
It's about the same, if you can swap the cam sensors you can swap the crank sensor as well. There are a couple of DIYs on here, just look around.
Old Mar 29, 2014 | 10:56 PM
Glikeme's Avatar
Alright a lil late, but I finally got the issue fixed with the CEL, VDC OFF AND SLIP lights. For a recap if your too lazy to read the previous posts, I initially had the three light s go off and the car took about 5 seconds to start and the lights stayed on. I plugged up the OBD 2 and got a P0340 code for camshaft position sensor bank 1, I replaced both sensors cranked the car up and had the same problem accept now it was a P0345 for camshaft position sensor bank 2. Two days later I decide to actually go under the hood and re-check the sensors and to my surprise, the sensor was in the engine but the clip was unclipped. As you've probably put together I attached it and the car started like a charm. So to all my NOOB's like me, the lesson learned is always check your work. It will save you a lot of headache.
Old Mar 31, 2014 | 11:16 AM
Blue Dream's Avatar
Glad you figured it out.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
Joshua615
Aug 31, 2015 12:29 AM
Jay 21
Aug 5, 2015 04:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
