High Stall Converters and 60's
Old Jul 23, 2010 | 11:21 AM
Structure's Avatar
I know a few guys on here have valve bodies along with a high stall convertor for their 5at's
im curious how well they helped improve peoples 60's at the track and how well a stock tranny holds up. i would think this would be the biggest part to getting a stock block 5at at the 12.0 range
this would be na or FI
Old Jul 24, 2010 | 11:02 AM
Tollboothwilley's Avatar
Not too many people have swapped out their torque converters. If you go over 350 torque or so it is recommended that you build the trans (for most people anyways) if stock 5AT.
The stock stall is 2800 which is pretty high already. Depending on what your setup is, you might not gain all that much from the TC swap.
What are you using your car for?
Old Jul 24, 2010 | 12:26 PM
Mr_pharmD's Avatar
that's not the true stall... it's more like around 2300.
Old Jul 24, 2010 | 01:33 PM
Brwn5454's Avatar
IF you have a line-loc and/or the correct tires...yes it will help your 60 ft times.
Explain your set-up and lets go from there.
Old Jul 26, 2010 | 11:00 PM
Structure's Avatar
well guess what im looking for is how to bring down the 60's and get nice launches out of the auto. im only looking to make about 350-400whp once i get a kit on and just get the most out of it
Old Jul 27, 2010 | 07:41 PM
Brwn5454's Avatar
I've got my stall set at around 3100, my car has been to the track once with the stall installed...everything else, city driving. Would I recommend it for a DD? No.
Hp/tq= 393/325
Your choice.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
