torque specification
Old Aug 13, 2010 | 06:09 PM
whoisthis's Avatar
Is there torque specification on the bolts for y-pipe?
I tighten those pretty hard with a box wrench. I guess is that when the bolts heat up when the engine is running, they expand and might crack the pipe. am i wrong?
Old Aug 13, 2010 | 08:40 PM
bigc's Avatar
Wings Nation
the OEM torque specs are in the attached diagram. it looks like 40 ft-lbs will work for both ends of the y-pipe.
Old Aug 13, 2010 | 09:03 PM
whoisthis's Avatar
Thhx for the diagram. I hand tightened the nut with a box wrench (normal length) pretty tight. Is this far too weak to reach 40 ft-lbs?
Old Aug 14, 2010 | 09:54 AM
Tollboothwilley's Avatar
You should be fine. I torque mine down to around 70 ft pounds. No problems ever. Exhaust bolts (minus the headers) aren't that important to worry about torque specs.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Cbohannan101
Sep 12, 2015 10:32 PM
