Help with my 6mt
Old Aug 21, 2010 | 08:53 PM
Christian.H's Avatar
Help with my 6mt
When I press in the clutch there is no noise, but when I release the clutch I hear a little raddle coming from the engine. I feel like my gears arent shifting as smoothly as they used to be but that was after the noise was going on tho. Also when i'm letting off the gas and slowing up and even just starting off i feel the gears aren't smoothing connecting and moving together. picture the gears working together and not firming moving together. i just have been noticing more and more. i plan on further looking into it, i just thought i would throw a thread up and see if someone that knows alot more then i do about manual transmissions would understand and maybe point out what could be wrong. This is my first manual too so thats why i'm still learning.
No negative feedback
Old Aug 21, 2010 | 08:54 PM
kind of a sloppy description but like i said i'm gunna further look into it. lol
Old Aug 21, 2010 | 08:57 PM
05G356MT's Avatar
Rattle when clutch not depressed = most likely the throw out bearing. Shifting not as smooth = try changing out your transmission fluid if you haven't done so recently. there was another issue similar to the gears not shifting smooth but i can't recall what it was called. maybe someone here knows what i'm talking about
edit: fount it if you're talking about gears grinding and not going in as smoothly check the transmission synchros https://g35driver.com/forums/nationa...n-synchro.html
Old Aug 22, 2010 | 11:22 AM
I have been told I hold the clutch when starting off for too long and to just let it out faster. Could this be a problem starter?
Thebaws11
Jul 2, 2021 11:36 AM
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
RWDguy4238
Sep 30, 2015 12:13 AM
