ugent help, replacing coolant fan
Old Aug 27, 2010 | 10:58 PM
He-man's Avatar
fan on driver side which attached to radiator is not working, is it coolant fan? if so, how do i replace it? do i need to take out the radiator in order to change it? is there a link or an article for this? thanks guys
Old Sep 22, 2010 | 05:08 PM
CBRworm's Avatar
20 Year Member
Both fans should run or stop together.
I had the dealer to mine under warranty (at 98K), they did not remove the radiator but took off the top hose and seemed to move it forward and bend everything out of the way to get it in there.
Be careful not to bend the AC lines too much coming from the condenser - they are aluminum and don't like being bent more than necessary.
They had to remove the air box and unbolt the A/C line (I know this becuase they left the bolts out)
Old Sep 22, 2010 | 05:41 PM
He-man's Avatar
thanks for the help guys, i replaced the fan's motor and it was easy to do, took about 1 hr but worth it and saved lot of money
KevinnnVo
Oct 14, 2024 04:33 PM
Blakearold
Aug 27, 2015 12:37 PM
Phenomenon9
Aug 9, 2015 01:34 AM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
