Midshaft/Center Support Bearing Noise?
Old Aug 31, 2010 | 05:09 PM
Jining's Avatar
Hello, I have been experiencing this "woowoowoo" type noise when driving. It is a rotational noise and increases with frequency as speed increases. It only makes the noise above 30 mph, mainly when coasting, both in neutral and in gear. When I begin to accelerate when in gear, the sound seems to nearly go away but I can still hear it faintly. If I accelerate with it in neutral when parked, there is no noise, so it definitely has something to do with the drive train.
At first I thought it was a rear wheel bearing, but now that I noticed that the noise seems to go away when the throttle is pressed, I am thinking center support bearing.
Any thoughts or experience with this sound?
Thanks.
Aaron
Old Sep 22, 2010 | 05:04 PM
CBRworm's Avatar
20 Year Member
I had a similar sound that came and went with throttle and was not affected at all by cornering, but mine was loudest around 55mph. I was sure it was either the carrier bearing or the pinion bearing because the noise seemed to come from the center of the car and sounded too 'fast' to be a wheel bearing. It turned out to be my left rear wheel bearings. A shop was able to listen to it in the air with a stethoscope. I was skeptical even after they told me they fixed it until I drove it. sure enough it was fixed. that was at 90K, within 5K my other rear wheel bearing went out. I did the front two myself just for piece of mind.
Yours could be anything, that was my experience.
Old Sep 28, 2010 | 05:28 PM
rpm06g35's Avatar
I had this problem on a friends car. The vibration due to a carrier bearing going bad is super obvious. I noticed a little wear on the upper side of the bearing (rubber) so what i did was play with the agle of the carrier bearing. Basically i added 1 then 2 then 3 washers per bolt as shims. Its an easy way of trouble shooting your noise it will either get worse or go away. Let me know what you find bro mike
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
