Exedy stage 1 with stock flywheel on 2005 coupe 6mt
Old Mar 22, 2012 | 10:00 PM
xiphilix's Avatar
What's up guys! Did you also replace the throw out bearing when you changed to the exedy stage 1 clutch with the resurfaced fly wheel?
Old Dec 8, 2012 | 02:06 PM
ajigga's Avatar
Hey I have the same set up act streetlight fly wheel exedy stage 1. how does pedal feel on engagement when does it start to bite. Mines is a lil past half of when taking ur foot off the pedal. But when I first got it is was grabbing right before half it's started to feel like the old clutch grabbing right at the top. The set up only has 260 miles on it so far. Thanks for any info.
Old Oct 19, 2013 | 01:35 AM
QX1's Avatar
QX1
hy
how is your clutch performing, i have also stage1 and it is burning like rubber, also i put luk oem dmf flywheel, any syggestions?
Old Oct 19, 2013 | 02:42 AM
ajigga's Avatar
Originally Posted by QX1
hy
It's holding up go the burnt rubber smell will go a way after awhile just don't remember how long it took. I just hate that it grabs right when I'm about to take my foot off the clutch. It's almost been a year since the install and I still stall on hills sometimes from the clutch grabbing at the top when I'm letting off the clutch.
Old Oct 19, 2013 | 03:15 PM
QX1's Avatar
QX1
I have driven with my new stage 1 clutch over 700 miles nad flywheel but reverse is terrible, whole car is shaking . 1 gear when driven sharply at takeoff is bit softer,but I am not content.
the pressure plate fingers are too stiff, they should redo their products. Some engineer has made mistake.
Old Oct 26, 2015 | 12:11 AM
_Superman_'s Avatar
Hey guys I'm new to the g35drive forum, I need help with my 2003 G35 coupe. I need a new clutch wanted to know what's the best setup for new clutch and flywheel? I called my shop and they trying to charge me 850 for Exedy clutch and resurface the fly wheel on car. What do you guys think?
mike730
Jan 12, 2018 04:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
driftsucky
Jul 15, 2015 12:38 PM
