'04 G35x - Gear Indicator blank
Old Sep 20, 2010 | 08:56 PM
franz182's Avatar
Howdy -
My wife pulled the G35 out today and when shifting from Reverse to Drive thought the transmission was slipping - she pulled back in the garage and shut the car off. I went out an hour later and the car will not start. Starter will not even click over - the indicator on the dash that shows the gear the car is in usually says "P" - it is blank now - I cannot get it to display anything - I have moved the gear shift to all the different gears - I still get nothing. With the key on moving the shifter to "R" the reverse lights do not come on -
Any ideas? I pulled the center console - I don't see anything wrong - not sure where the position sensor is...
Thanks in advance - I am hoping this is a simple fix, but fear it may be costly
Old Sep 20, 2010 | 09:02 PM
ELMACHOGERACHO's Avatar
usually when that happens its either a tcm or valve body
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Claudiu
Sep 26, 2015 01:04 PM
vamarris
Sep 26, 2015 12:56 PM
