I haven't changed my tranny fluid for over 30k miles, what brand/type. please read
Nov 11, 2010 | 04:44 PM
i have a slight minor minor grind going into 2ns gear, i expierence it only when i dont let the car run for at least 5 min before driving, also could it be that i havent changed the tranny fluid? i called up my local transmission repair shop, he told me he willl drainn and fill up the tranny fluid but i have to get the fluid from, the dealer ship!
what fluis should i get? and one changed the fluid recently
Reply 0
Nov 11, 2010 | 05:07 PM
just called my local dealership ( ray catena inifinti of edison nj) told me its $115 for a drain and fill not sure if its a flush and fill and they told me they use "nissan matic s" ? is that good enough for me? also is there flusids to be changed, i was reading a thread where there is gearbox fluid? if so where is it located, my second gear is agitating me !
Reply 0
Nov 11, 2010 | 05:21 PM
Ok relax. 30k is the NORMAL change interval for our transmissions. If you have AT I would recommend you listen to the dealer and use Matic-S fluid. Where you get it done is up to you.
Search is your friend. This question has to have been asked many many times.
Reply 0
Nov 11, 2010 | 05:30 PM
i searched and searched, i cant find a clear answer, lol. trust me i like to search before asking ? .. and yes my transmission is 6mt.
Reply 0
Nov 11, 2010 | 05:32 PM
Quote: just called my local dealership ( ray catena inifinti of edison nj) told me its $115 for a drain and fill not sure if its a flush and fill and they told me they use "nissan matic s" ? is that good enough for me? also is there flusids to be changed, i was reading a thread where there is gearbox fluid? if so where is it located, my second gear is agitating me !
Drain and fill is not a flush. Drain and fill should be done only if you haven't ever had your oil changed at a very high mileage. Everyone that I've ever talked to favors flushes over drain and fills. Flushes tend to be double the price but are worth it. I got one a 62k, just hit 80k and about to get one within a couple weeks. You might also wanna flush your rear differential fluid which would help as well.
Reply 0
Nov 11, 2010 | 06:47 PM
so the rear differential fluid is totally different from the tranny fluid? is there anything else i should tell the dealer ship to change/replace ?
Reply 0
Nov 12, 2010 | 02:20 PM
any more replies?
Reply 0
Nov 12, 2010 | 02:24 PM
Yes Tranmission fluid is Different from the differential.
If you have an automatic then get Matic-S you can find it cheaper online.
Reply 0
Nov 13, 2010 | 05:57 PM
Quote: so the rear differential fluid is totally different from the tranny fluid? is there anything else i should tell the dealer ship to change/replace ?
your differential will normaly take about 3 quarts of 80/90 gear oil, not synthetic just plain ol 80/90. I did mine today and there was nothing to it, probably took me 45 mins in all.
Reply 0
Nov 14, 2010 | 11:17 AM
is there anyone i can go to besides the dealer to change my differential fluid? dealers charges $115 an hour labor lol
Reply 0
Nov 15, 2010 | 03:06 PM
Reply 0
Nov 15, 2010 | 03:08 PM
Quote: your differential will normaly take about 3 quarts of 80/90 gear oil, not synthetic just plain ol 80/90. I did mine today and there was nothing to it, probably took me 45 mins in all.
3? Its only 1.6 quarts or something like that.
Reply 0
Nov 15, 2010 | 04:16 PM
yup, diff only takes 1.5 qts. I used 75-90 Mobil syn.
6mt also takes the same oil.
grind in 2nd could possibly be your 2nd gear syncro going out.
change fluid first then see if that works, if not, I hope you have warranty.
Reply 0
Nov 15, 2010 | 04:43 PM
no i dont have warranty and yes its 6 speed?? so wat fluid do u recommend for the rear differential fluid change?
Reply 0
Nov 15, 2010 | 06:26 PM
80-90 amsoil
75-90 mobil 1
all syn. anything syn will work, since you probably dont track.
Reply 0
