Help with a front left hub and bearing.
Old Dec 14, 2010 | 06:36 AM
DINGO1890's Avatar
I took my g35x into the infiniti dealership yesterday becuase I was getting some vibration and loud humming noise coming from the front of the car while doing 50+ mph. They told me that its going to need a new front bearing ($650 w/labor) and it may need a new hub ($350 w/labor). It almost seemed like he was trying to get to a thousand. My questions: Is this a standard price for this kind of repair? also... how hard would it be to do this repair myself? Are there any DIY videos?
Old Dec 21, 2010 | 11:35 PM
CBRworm's Avatar
20 Year Member
Try a good Indy shop.
For the front in a regular RWD you can get the oem parts pressed together and ready to bolt in, slightly harder than a brake job. I don't know about the x
Old Dec 22, 2010 | 11:16 PM
Gdirtyfiver's Avatar
Is there such thing as a "wheel hub assembly" for the front 05 g35x that comes with bearings and hubs together in one piece/pressed. I found TIMKEN has a wheel hub assembly at parts geek.
http://www.partsgeek.com/catalog/200..._assembly.html
I'm a bit skeptical because as far as I know its suppose to be 2 separate pieces.( hub and bearing). Can anyone confirm this?
Old Dec 22, 2010 | 11:37 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can get them separate but the install is much easier if you get the whole assembly.
Cajuncowboy
Jun 21, 2021 09:47 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Steering & Suspension
Aug 3, 2015 02:44 PM
papo020
Jul 17, 2015 10:30 PM
