High Clutch Engagement...
Sorry to beat a dead horse gang...BUT I just bought my G a few days ago. It is a 6MT with 96K on the odo.
I am unsure if the clutch has ever been changed. I printed the service history from the local infiniti dealer but there was nothing about clutch issues anywhere in the history.
My clutch engagement is VERY high...it engages the last 2 inches of the pedal. When the clutch engages it's perfect and does not slip at all anywhere...even at WOT.
I topped off the fluid and it seemed to help a little...could there be air in the fluid? How would I flush it?
any thoughts?
any thoughts?
Sounds to me like you just need to adjust your clutch. I had the same issue when I bought my car, but it's very much improved after following this thread:
https://g35driver.com/forums/engine-...ent-point.html
Hope that helps. Let us know if you have any more problems with it.
How many can I go safely?
Is there a way to tell if my clutch is new or just getting worn down? Any tests I can do?
thanks
I think I went about three to four turns. You just want to make sure your clutch is still fully engaging/disengaging, so don't do too much.
If you clutch is still grabbing well and not slipping, it's not worn too bad.
I just purchased a 2004 with 95k miles and had the same problem. The car was new to me so i wasn't sure if this was normal or not...eventually the clutch slave cylinder and hydraulic line broke, (clutch pedal was stuck to the floor), and were replaced for about $300. This totally changed the engagement point so that the engagement happens immediately like it should.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
jbmw002
Sep 10, 2015 12:54 AM
