Question about 3rd gear
Old Jan 6, 2011 | 01:56 PM
dae's Avatar
dae
Well I have read many threads about 3rd gear grind and syncros being bad, but I think my issue is a little bit different and wanted to see what you guys thought.
When driving only and shifting into 3rd gear, I sometimes, maybe 20% of the time get a single "TICK" that I can feel on the shifter as I go into 3rd gear. It doesn't prevent me from going into gear, or make a GRIND feeling, its more of a single "TICK" that you can definitely feel on your hand as you go into 3rd gear. 80% of the time it shifts smoothly into gear, but about 20% like stated above I feel that knock on the shifter.
Any ideas what this could possibly be? I have an 05 G35 6MT @ 48K miles. Probably going to change out the tranny fluid and see if that helps at all. I was unable to find any threads with people who have a single knock rather than most who have an actual GRIND. Thanks guys!
Old Jan 7, 2011 | 02:19 PM
dae's Avatar
dae
Drove around some more today and its definitely not a quick "ZZZZ" grind feeling. Its a single "KNOCK" that I can feel on my hand when shifting into 3rd probably 15% of the time. However, that gear is starting to feel pretty knotchy as well even without the knock. Any suggestions? Gonna do a tranny drain/fill hopefully this weekend.
Old Jan 7, 2011 | 03:39 PM
nghiars's Avatar
could possibly be time for a fluid change... especially if you area somwhere it gets cold.
Old Jan 8, 2011 | 07:07 AM
626Gthirtyfive's Avatar
It's normal. Our tranny is right under the shifter so it can get notchy. I got used to it and liked it after awhile.
EDIT: but changing your fluid won't hurt
Th611
Oct 27, 2015 03:48 PM
Ednica87
Sep 5, 2015 02:59 AM
Frostbite91
Aug 20, 2015 07:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
