Why you should change you Differential Oil at 30K miles
Old Jan 11, 2011 | 02:16 PM
DivZero's Avatar
I believe the service manual says it's just suggested to check it. Here's a vid of the oil (click image).
Old Jan 11, 2011 | 02:18 PM
thescreensavers's Avatar
Mr.202?
I changed mine at 39k it was very clear and the plug had almost no buildup on it.
Old Jan 11, 2011 | 02:20 PM
teahead's Avatar
is that whitey milk stuff in it? I.e. water?
Old Jan 12, 2011 | 12:41 AM
DivZero's Avatar
Yes it is white milky stuff. I doubt it's water, probably just reactants from oil breakdown. As far as I know the oil is the original factory fluid. I replaced it with Lucas diff oil.
Old Jan 12, 2011 | 12:45 AM
JAYY-G35's Avatar
I never changed mines, i'm currently at 90k miles.. I guess i need to do mines asap.
Old Jul 1, 2011 | 06:13 PM
buzzking's Avatar
I bought my car with 52K miles and apparently the guy lied about doing the maintenance... which I found out when I did my 60K maintenance myself.
The differential fluid was DARK and nearly black which a **** load of build up on the magnetic bottom plug.
Same goes for the tranny fluid.
90K is pretty bad... I hope you get it done soon so you don't face the same shock I did when replacing the diff. fluid!
Does anyone know what problems might arise from not replacing the diff. fluid?
Old Jul 2, 2011 | 11:21 AM
DivZero's Avatar
Just an update, I think the synthetic fluid is causing a whirring when the fluid is cool. Will switch back to conventional soon and post the results.
Old Jul 2, 2011 | 11:28 AM
faiz23's Avatar
Plz describe this whirring you are talking about. I used Mobil 1 synthetic and I actually hate there engine oil but there diff oil was good quality.
Th611
Oct 27, 2015 03:48 PM
Gip
Aug 24, 2015 05:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
