Drop from 4.08 to 3.3 possible?
Old Feb 9, 2011 | 01:27 PM
LowUFO's Avatar
Question Drop from 4.08 to 3.3 possible?
Will the 3.3 (open) Ring and Pinion gears would work in a 3.5 (VLSD) diff. with a Quaife diff. installed? I am currently running 4.08 gears, and the gas is killing me. I was going to swap back to the 3.5's, but if I could go 3.3, that'd be great.
Basically, is the ring gears bolt pattern the same on all the diffs? Are the pinions the same length?
Thanks,
Ian
Old Feb 9, 2011 | 01:35 PM
kennymo's Avatar
i will trade you my 3.3 out of my sedan for your 4.08
Old Feb 9, 2011 | 01:39 PM
LowUFO's Avatar
If they are a direct swap, I might be interested. I currently have the diff. out of the car at this time too.
Ian
Old Feb 9, 2011 | 01:43 PM
kennymo's Avatar
Ian
what is the year and car its coming out of? first gen sedan?
Old Feb 9, 2011 | 01:44 PM
kennymo's Avatar
oh nvm i see its a 05 sedan. then yes should be a direct swap
Old Feb 9, 2011 | 02:15 PM
LowUFO's Avatar
It's a 1st gen. Sedan and I currently have the 4.08's in with a Quaife diff., and Diff cooler, etc. I don't want to swap pumpkins, just ring and pinion gears. I might just go back to the 3.5's, and sell the 4.08's. I need the $$$. LOL
Ian
Old Feb 9, 2011 | 02:42 PM
LowUFO's Avatar
Ok, after talking with OCG35, the 3.3's will not fit the Quaife diff. I have. I have the Quaife for the 3.5 VLSD cars, and the 3.3 open diff's have a thicker ring gear, and ARE NOT and direct swap. (not sure about the 3.3 VLSD diffs)
Thanks for the help everyone.
Ian
Old Feb 24, 2011 | 05:21 AM
626Gthirtyfive's Avatar
How much did your mpg change after you went from 3.5>4.1? Did it feel alot quicker?
Old Feb 24, 2011 | 04:29 PM
LowUFO's Avatar
I went from about 16 MPG (3.5 FD) to around 12MPG (4.08 FD). With my current commute being about 50 miles in each direction, I was having to fill up about every 2-2.5 days. I was getting about 220-250 miles out of a tank, and that was all freeway driving. With the 3.5 FD, I am getting over 320 miles out of a tank (freeway).
The car was incredibly quick around town, from stoplight to stoplight, but there was no "top end" on the freeway. I could surge forward to pass with no problems, but "ran out of steam" anything beyond that.
Basically, the 4.08 FD is great for around town, but if you have a long commute, they are not the right choice for you.
Hope this helps,
Ian
Old Mar 1, 2011 | 03:40 PM
KSWAY's Avatar
Just buy my 3.3 open diff and swap it out with yours
Old Mar 4, 2011 | 01:10 AM
boostedforlife's Avatar
i have a 3.5....... hmmm
right? 05 6mt is 3.5?
Old Mar 4, 2011 | 01:32 AM
LowUFO's Avatar
Yes, '05 6mt has the 3.5 FD.
Ian
Old Mar 4, 2011 | 02:25 AM
How long does it take to drop the diff and take out the ring?
so I wouldnt need anything else other than your ring and pinon?
Let me know if you were trying to do a trade or sell etc, pm me. Thanks!
Old Mar 4, 2011 | 12:19 PM
LowUFO's Avatar
The whole job could be done in a single day if you have all the tools needed, and parts needed. (but most people don't have a hydrolic press in their garage) I have a friend that works at a dealership, and has access to the shop/tools.
As for parts, I would recommend getting new bolts to attach the ring gear to the VLSD. They run about $3.00 each, and you need 10 of them. You also NEED a new Crush Sleeve, and oil seal for about another $30. These are what I would say are the "need to get" parts. If you have a good amount of miles on your car, you may want to look into getting new bearings, but they are a little pricey. You may also need to get some shims to properly "center" the VLSD in the housing to line up with the new pinion gear.
I don't want to turn this into a "For Sale" thread, so PM me if you are interested. Z1 Performance has the 4.08 gears listed at $565 + $25 shipping. They also have the "Install Kit 1" that has all the "needed" parts for $32.50, and "Install Kit 2" for $299. (new bearings, etc.)
Let me know if you are interested, and I will PM you the price I am asking.
Ian
Old Jun 24, 2011 | 12:35 PM
almost3flips's Avatar
I'm interested. 3 month bump!
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
