Rear diff fluid and amount?
Old Feb 14, 2011 | 11:01 AM
Nightm4re's Avatar
Owners manual doesn't specify amount...
Just curious how much fluid you put into your rear diff when you did a drain&fill?
also, did you use the recommended type from your owners manual? Mine is automatic and it states to use API GL-5, viscosity SAE 80W-90*5.
Old Feb 14, 2011 | 11:26 AM
mkvl127's Avatar
just drain and fill until fluid starts coming out of the fill plug..make sure u loosen the fill plug before you drain to make sure you can refill..
Old Feb 14, 2011 | 11:35 AM
msommers's Avatar
I used this stuff:
Took about a bottle and a half-ish.
The advice above is sound - The whole process is very easy.
Old Feb 14, 2011 | 12:14 PM
herrschaft's Avatar
I've always used 2 quarts.
Old Feb 14, 2011 | 06:31 PM
brandon1978's Avatar
Service manual states 3 US pints, which is equal to 1.5 quarts or 1.4 liters. Like mkvl127 said above, just fill until it starts coming out the fill hole.
Old Feb 17, 2011 | 04:51 PM
3maxima's Avatar
I used a little under 2 quarts. When it was about done dripping out the old stuff I shot a little of the new in there and let it drain out too. Then filled until it ran out the top and had a little left over.
derres
Aug 28, 2015 03:27 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
