03 auto transmission problem. help
Old Jan 19, 2012 | 11:33 AM
jeffjcausey's Avatar
its an 03 sedan with the 5at transmission. the car has 103xxx miles on the car. the problem started off about a month ago and wasnt near as bad as it is now.
whenever i would be cruising around 50 and be in 5th gear, if i were to slowly press on the gas to accelerate, the motor would rev higher, but the speed would stay the same. it almost felt like a clutch slipping on a manual. only if i gave if enough gas the transmission would downshift and lets say its not the smoothest downshift i could ask for. just yesterday, went and got the transmission fluid changed, and now its even doing the problem when im simply starting off in 1st. i was at a red light going up a hill on the way to work this morning, and the problem occurred just as before...but this time it was in 1st. from a stop, i let off the brake, and press on the gas. the motor starts to rev up to 3k+ but barely any power is going to the wheels. then a hard thud, and the car takes off. and like i said, especially for this instance, it feels like a slipping clutch on a manual.
any help or some sort of solution would be greatly appreciated. thanks guys
Old Jan 19, 2012 | 05:42 PM
CLyons0203's Avatar
valve body is shot. eventually it will cause the clutches to burn up. Valve body at dealer brand new about $800-$1000
Junk yard transmission with about 50k miles $500-$700
CLyons0203's Avatar
should get a code for hi\lo clutch solenoid valve
Old Mar 4, 2012 | 12:08 AM
Azntran517's Avatar
Smh my car(111k) started doing that like 2-3 days ago! Should i still get a code if my check light is not on? I haven't flush the trans fluid yet but going to do that first thing monday.
Old Mar 7, 2012 | 08:10 PM
Azntran517's Avatar
I've been pricing some trans around the are (04 with 30k for asking $700). My question is will a coupe or a 350z trans also work for my 04 sedan or what type of trans should I look for? Thanks.
Old Apr 22, 2012 | 07:42 PM
quitbrite's Avatar
same problem
same problem here. Drive in tiptronic in 4th. It helps.
Old Apr 23, 2012 | 12:50 AM
Tolboothwilley™'s Avatar
I'd be willing to bet its NOT your valve body
If anything it is more likely to be clutch packs slipping. This is why I always recommend people put better cooling on their transmissions. Factory is insufficient like 99% of the time. It will get your through warranty, but if you really want an AUTO to hold up you need to keep temps from climbing past 220-230*.
I am running a B&M cooler for my trans fluid - i run it in series with my stock cooler.
I have an extra Valve Body for a 2003 5AT in my possession. I'm willing to sell it if you are looking to buy one. has about 40K miles it.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
dcsbh1
Oct 1, 2015 03:15 PM
