sudden loss of power. motor is not climbing rpms quick. any ideas as to why?
SubscribeRegistered User
My fuel pump went out this morning.I got my g tow to guy who deal with infinti and nissan. He call me up around 4pm and said fuel pump bad. He check all the basic part nothing wrong. Its going cost me $650
Quote:
http://www.z1motorsports.com/350_g35...oducts_id=3189Originally Posted by G-Ryder03coupe
I hooked up a scanner to the car and got that' same code. I went AutoZone looking to buy the scanner and they said they had one for $30 and one for $140. Also they said they didn't have the harness. Were did u order ur parts from? I want to make sure I get the right parts
i went with the $30 sensor also, i searched and can't find any info on the difference between the cheaper one and more expensive one. also most parts stores will have a cheap one and an expensive one.
I took everything out intake manifold n fuel rail. But I can't find the sensor! Any help?
I ended up finding it I didn't realize I had to take the cover under the whole intake manifold took me forever. I have to finish the job tomorrow cause I had to orderthe intake manifold gasket and the harness from infiniti.
I haven't put it all back together cause I'm waiting for Infiniti to send me the harness and the manifold gasket. Should be up and running tomorrow though hopefully this solves the problem and I get my power back
Put it all back together and the car is running better then ever! Took me a few hours but I did it! Lol learned a lot in the process lol
cool, i just put my new harness on last night. test drive this morning and no codes, hopefully it lasts. i noticed in the picture your sensor was turned a different direction than mine. i wonder if that matters.
i'm very happy how easy this car has been to work on compaired to other cars i've had. i decided to swap in some new copper plugs too since i was under there and thermal wrapped my injen cai to help with heat soak.
My knock sensor has never been replaced so that's the way they put mine from factory. So I put it the same way. And yea it really wasn't that hard at all to do. It just took me a little while because I wanted it to come out perfectOriginally Posted by tashspop
cool, i just put my new harness on last night. test drive this morning and no codes, hopefully it lasts. i noticed in the picture your sensor was turned a different direction than mine. i wonder if that matters. i'm very happy how easy this car has been to work on compaired to other cars i've had. i decided to swap in some new copper plugs too since i was under there and thermal wrapped my injen cai to help with heat soak.
I think i'm having the same issue with my '06 G 5AT. No power, accelerates pretty weak and drives my rpms high. No engine light and haven't checked for codes (making a trip in a few to auto zone to check for any).
Think this may be the same issue with mine?
Where did you get your knock sensor from and what part # was it?
I got mine from auto zone they have a $30 one and a $140 one they just matched up the number off my knock sensor and it matched up with the 30 dollar one. The harness I had to get from Infiniti it cost me 107. I think my code was p0327 if u get that you already k ow whAt it is.
That is good news.
Well I wasn't getting a code at all. Talked to my buddy about it and he had the same issue with his car. Loss of power, acceleration with high rpms and no cel/mil codes. He replaced his camshaft position sensors and the issue went away; but only after he got parts from the dealership because the autozone parts he got were bad on multiple occasions.
