Clutch and Flywheel Replacement
Old May 6, 2012 | 05:09 AM
maxpusher's Avatar
20 Year Member
Hello,
I have about 150,000 miles on my car, and it has the original clutch. I bought a Fidanza lightweight flywheel with an ACT clutch. I wanted to know what other parts I need to replace while I drop the transmission. I am planning on replacing the following:
Throwout bearing
Pilot bushing
Clutch pivot ball
Please provide comments on other wear items I should be aware of when replacing the clutch and flywheel. Thank you and hope to hear from anyone soon.
Old May 6, 2012 | 05:37 AM
Jairen's Avatar
Whenever I change out a flywheel, I always buy new flywheel bolts.
Old May 8, 2012 | 06:10 PM
p0onsta's Avatar
would also recommend changing the rear main engine seal, front and rear transmission seals, transmission fluid, clutch fluid, clutch slave cylinder.
Old May 10, 2012 | 04:18 PM
DEMoLITIoN's Avatar
What year is your car? It if it an 03, it is a good idea to replace to the 04+ clutch fork kit. Its way stronger for that heavy duty clutch.
flywheel bolts, SS clutch line, transmission seals and fluid, rear engine seal is a good idea, remove the retarded spring off the clutch pedal.
Old Jun 9, 2012 | 06:12 AM
Plam's Avatar
Where would I get the seals?
jsimonk
Dec 22, 2023 03:49 PM
TurboEE
Jul 31, 2015 10:41 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
