Normal flywheel chatter?
Old May 27, 2012 | 10:49 AM
DiGil's Avatar
Ok, so I understand that flywheel chatter in neutral is normal, I've lived with it for years. However, I just started hearing a different noise that I think might be related. If I'm decelerating to a near stop in 1st or 2nd, I hear a rubbing/scraping noise below about 2.5k. It stops shortly after I push the clutch pedal in.
Any ideas what this might be? It's all original parts on my '05 6MT. Everything except the OC replacement engine has about 87k on it. Maybe it's just time to replace the clutch and flywheel? It's not slipping at all, though.
Old Feb 14, 2013 | 09:35 AM
Avalos93's Avatar
I actually have the same problem with my g35 and I honestly think it time to replace the flywheel and clutch and plus it will be good just to replace. I would feel comfortable daily with a stage 1 clutch.
Old Feb 14, 2013 | 10:17 AM
gary c's Avatar
Throw out bearings also make a ton of noise, that maybe what you're hearing. They get dry, worn and eventually freeze up so you can't go into gear. I put 117K miles on the clutch in my last '92 300ZXTT and only replaced because of a rear main seal failure. With your high mileage G and if you don't track your cars stay with OE clutches, look how long they've lasted....Gary
Old Feb 19, 2013 | 02:45 AM
RCL's Avatar
RCL
I've done 2 track events in my G so far and car is holding up fine. I'd probably go aftermarket clutch though, when it's time to replace it.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
aaron3719
Sep 29, 2015 10:12 AM
