Clutch noise on cold starts
Old Jun 8, 2012 | 05:47 AM
Plam's Avatar
Yeah... so recently I bought a IP G35 and the last owner told me that the previous owner had a "racing clutch" installed, he did not know what brand and that it needed to be warmed up before running, at least 5-10 minutes of waiting. Although he did give me a new F1 racing clutch which I don't plan on installing bc of all the bad reviews it has.
What sounds fishy to me is that.. I don't think you can warm up the clutch with just leaving the engine idle. Plus, I looked everywhere and nowhere does it say that racing clutches needed to be warmed up before using. (Only carbon clutches, but even then I don't think its suppose to make that noise)
The noise occurs when I turn on the engine, if I don't let go of clutch after ignition I'll hear a grinding/whirring noise and if I try to use my car before the engine warms up It'll make that whirring sound but after a couple minutes the noise goes away...
I'm wondering if this is really because it is a "racing clutch" or if its because the clutch needs to be replaced.. or I don't know.. throw out bearing broken? But I've done a lot of searching and if the throw out bearing is broken it makes a whistling noise..
BTW the clutch works fine after being warmed up, no slipping or anything.
Old Jun 8, 2012 | 09:45 PM
Plam's Avatar
bumppp
Old Jun 9, 2012 | 09:14 AM
Libra4220's Avatar
It could be a warn out throw out bearing, or pilot bushing, or the trans could be low on oil because the MT does operate with oil SAE 79W-85 or 75W-90 I found that these two caused my trans to whine while shifting so I got the dealer fluid and it was quiet again, not cheep though.
Old Jun 11, 2012 | 11:01 PM
Mrs. Robinson's Avatar
Dealer Fluid
I'm having a weird noise come from my clutch, when the clutch pedal is pressed in. I'm told it's the throwout bearing… It doesn't happen all the time but enough to **** me off!
So, getting dealer trans fluid should fix this problem?
Old Jun 12, 2012 | 08:01 AM
Libra4220's Avatar
No Im not saying it will fix it. just a shot in the dark, may or may not fix it.
Joshua615
Aug 31, 2015 12:29 AM
Frostbite91
Aug 20, 2015 07:20 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
