Transmission bounce
Old Jul 12, 2012 | 09:18 AM
LouisBPuller's Avatar
Question Transmission bounce
Greetings all,
Newbee here posting for the first time. I've hit the search engine here to the best of my abilities. If the answer is here and I missed it it's probably due to a lack of technical terms on my behalf. If that's the case, sorry to bother you all.
With that said, here's my issue - question. I have an 06 G35 auto w 60k miles. At low speeds and low rpms my transmission starts to bounce like it wants to come off the car e.g. cruising 40 mph at around 1500ish rpm and you head up a slight incline and the rpms drag. If it doesn't downshift, randomly here is where my problem shows up. To get it to stop you can either let off the gas or mash it. If you hammer the car this issue never comes up (I know, there's the answer) and it shifts well . No noises or vibrations to report other than this random bouncing issue.*When it starts you can see the damn gearshift*bouncing*in the*console... crazy and becoming more frequent.*
I do know for certain that my rubber - oil filled bushing in the rear cross member has split (like so many others I've found here), but I'm told that this doesn't fit this issue. I don't know the part number, but according to what I've found here Infiniti doesn't sell that bushing, only the entire member for $700 ish..
Any advice would be greatly appreciated. I'm not a wrench so it's garage bound regardless, I'd just like a info before getting dug out.*
Thanks for all of your time.
Seems the firewall at work blocked my post, so I'm going*mobile. I'm hoping this doesn't post twice.
Old Jul 13, 2012 | 12:12 AM
Algy's Avatar
I believe there is a tsb on this issue or a recall or something..
I know what issue you speak of.
It has to do something with the transmission (valvebody) not being able to unlock and go into a lower gear.
I have the tsb on my computer at work but thats all I know of now.
Old Jul 13, 2012 | 10:25 AM
Thank you! I'm on that as soon as they open today. I hope you're right!
Old Jul 13, 2012 | 12:15 PM
Wow, now that I search here for valve body I see many posts matching my issue. Also found the tsb you mention. Thank you! I knew my lack of terminology was killing me.
Old Jul 13, 2012 | 12:31 PM
Algy's Avatar
Awesome. Yeah I recently upgraded my VB. (transgo) and the issue has yet to pop up again. Although my sisters g35 (not upgraded) still has the problem from time to time.
Old Jul 13, 2012 | 12:57 PM
G35 Dream's Avatar
O had the same problem and I put a new valvebody and transgo shift kit in and this stopped.
Old Jul 14, 2012 | 10:27 AM
After 15 minutes of mad doggen the dealership they "found" an extended tranny program! I'm getting repaired on Wednesday. This deal expires at the end of July or 70 k miles. The quote from Infiniti was $1600.00
Great timing ..
Big thanks again for the info!
As expected my after market warranty rejected the claim. It actually lists valve body on the brochure but it has electricity flowing to it
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
