Disable Clutch/Neutral Safety
Old Mar 22, 2013 | 03:57 AM
ImElvis's Avatar
Basically I want to start my 6MT without pushing in the clutch.
My friend disconnected a clip near his clutch pedal on his EVO 8 and DSM, and I was wondering if anyone knew a similar method for the G35?
I've searched through this forum and others along the lines of "clutch, neutral safety; start car without clutch" etc. and found DIYs on other cars but wiring is different of course.
Old Mar 24, 2013 | 10:09 PM
OBsessed's Avatar
When it comes to wiring nothing on our cars is as easy as it should be, lol.
I can't help you but I'd recommend asking around at good car audio / alarm & remote start installers. If you're doing a remote start on a manual trans you need to bypass the neutral safety switch (which, if this is why you're asking - make sure add SEVERAL mercury cutoff tilt switches!) so they may be familiar with it. If it's a good installer and you're friendly enough they might even be willing to print out the schematics for you (I know DEI/Viper had a database back in the day for their authorized installers that laid out the color combo and location of every pertinent wire you could want, I imagine it's still around).
Old Mar 25, 2013 | 01:10 AM
saywat?'s Avatar
im gonna throw this idea out there lol. u could probably tape or tie strap the clutch swith to the pressed position.
Old Mar 26, 2013 | 06:46 AM
ImElvis's Avatar
Agreed on that wiring part.. I haven't really done anything to my car, but the few things that required wiring.. they're exactly as you describe it hahah swapping a headlight bulb is a bit extreme compared to a Honda. Although, thanks for chiming in. I'll ask around.
Hm. For some reason I didn't think of this.. my assumed concept of the clutch pedal was something else. I will definitely give this a try first. Thanks!
StreetStandard
Accessories-Vendor
67
Aug 15, 2016 02:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
.cakestar
Aug 4, 2015 09:05 PM
