will the 350z carbon fiber drive shaft fit a g35
the 350z track model has a carbon fiber drive shaft from factory. what i want to know is will it fit on a g35 coupe? i here the wheel base is longer on a g35. but is the lengh of the rear to the tranny different, maybe the tranny in a 350z doesn't sit in the same place as the g35. if anyone has an answer to this question please let me know.
driveshaft
The "midship" front clip between the two Z vs G are identical, however,the G35C is longer from the tranny back.
That's a good question. I'm wondering how much the Z CF driveshaft weighs compared to the G driveshaft. Could possibly free up a little bit of drivetrain loss.
EDIT: Posted too late.
loss
Everyone goes with the bling of 19"ers but they just add to rotational loss.
Originally Posted by g3po
Lighter wheels will buy you more.
Dave
Originally Posted by caelric
Of course, the stock 19"s on the '05's are lighter than the 18's....
Dave
Dave
1 inch further away, to be exact...
To really figure it out, you would have to find the rotational moment of inertia, and that is not a simple thing. Whichever one has a lower rotational moment of inertia is the one easier to rotate, which means less HP is lost to the wheels.
Dave
Dave
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
It's not only a matter of the rim weight, the tire weight is much more important. Tires weigh as much if not more than most rims now. And the mass is farthest from the rotational center.
I think all 350Z's have the carbon fiber drive shaft. But you wouldn't be able to tell looking at stock 350Z vs G35 dynos. So unless it's a simple bolt on, I don't think it's worth the swap.
The track 350Z's do tend to dyno higher though, due to the lighter rims.
the tire weight is just as important. but there are differences with tire compounds as well. sometimes a heavier tire has better traction and sidewall strength (potenza), and sometimes it has heavy weight and low traction (when compared to other tires of the same category (avs, 711-712's etc..)), and sometimes it is lighter and has very decent traction (t-1's). it's all preference. but the tire is the outmost weight of the inertia, therefor has the biggest impact on rotational mass. basically, if you're into weightloss, check for tire weight as well, ...and xenadrine. i had a friend that lost 56 lbs., shaved a tenth off his 1/4 mile.
Thanks Guys For The Info On The Drive Shaft. Now Does Anyone Know Who Might Be Making One Or Who Can Customize One For Me. At A Reasonable Price, I Don't Mind Paying But Don't Want To Get Rip.
