Trans drain & fill
Old Oct 16, 2013 | 05:16 AM
goodkuush's Avatar
Trans drain & fill
hey guys i just hit 140k on my 04 g35 sedan AT i was wodnering if it would be a good idea to do a drain and fill on the trans? i have no idea if its been done before, i dont want to flush it because that might cause problems. i just wanted to know if the drain and fill would be safe and problem free. im just looking to refresh my G a little
Old Oct 16, 2013 | 09:51 AM
jkuo's Avatar
Drain and fill shouldn't hurt since it's only like 4 quarts or so you can get out that way. Less than half the fluid. Since the fluid isn't lifetime or anything, it's way past due.
Old Oct 16, 2013 | 09:55 AM
Urbanengineer's Avatar
Check the color of the liquid. Ultimately you can get the fluid tested through your dealer to see if it is adequate for a full flush. We typically tell members only to do the drain and fill because if you have a weak transmission at the end of its life this can only cause problems.
Old Oct 16, 2013 | 10:21 AM
JOKER's Avatar
CLUB MODERATOR
full flush does not require you to go to dealer, you can do it at home. Doing a pan drain is not very efficient in your case, you are facing several issues.
1. You don't know if drain or flush was ever done before, if it was they might have used different fluid than you going to use and that might cause issues.
2. If your fluid was never changed, you have Nissan matic J in there, but it's so old that you might as well flush it all.
Follow this very simple video to flush your system with new fluid
http://infinitihelp.com/diy/gcoupe/p...on_service.php
Old Oct 16, 2013 | 06:28 PM
goodkuush's Avatar
if i go to the dealer can they tell me if i have the j matic in there or not i just want to drain and fill so i dont want to mess anything up or mix fluids
Old Oct 16, 2013 | 09:24 PM
markc's Avatar
Drain & fill with Valvoline multivehicle. Read the back label; it is a replacement for matic j, matic d, and so on. I did a drain & fill with it about 750 miles ago on my '05 sedan with 0 issue. It has 135k on it and I have no idea if the fluid was ever changed-I doubt it. I plan on doing the drain & fill several more times @ about 250 mile intervals until most of the fluid is new. Sort of like a gradual transfusion.
Old Oct 16, 2013 | 10:51 PM
gary c's Avatar
Only use the Nissan recommended fluid...nothing else!!!
You can do a drain & fill without issues! Find an independent shop that uses the correct fluid or Nissan since they charge far less than the Infiniti stealerships! If you discover the trans fluid really dark have it changed again in a few months for the health of your trans....Gary
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
G35CO
Sep 4, 2015 09:27 AM
