2003 5AT Transgo Issue
Old Jan 5, 2014 | 11:47 PM
  #31
froggy88's Avatar
I get the clunk 2-3. So I'm not sure it's right for me either :/
Does yours clunk in D or M mode? Also how bad is it?
Old Jan 6, 2014 | 12:48 AM
  #32
Urbanengineer's Avatar
On in M when I push hard and shift in the 3-4K range. It's really touchy on that area. If before 3K or after 4.5k it's fine...?
Old Jan 6, 2014 | 02:26 AM
  #33
froggy88's Avatar
I see. On my way home tonight ill experiment and see what mine is like >2k vs 3-4k range. It doesn't seem to matter what position the throttle is at for me it bangs if im WOT or if im applying a tiny amount of throttle.
How bad is your clunk? Mine is a pretty loud bang!
Old Jan 6, 2014 | 08:07 AM
  #34
You know what it sounds like. It's the weirdest type of up shift noise. Not clank or blam, but a clunk or think or thump. "Sound out these words."
Old Jan 6, 2014 | 06:27 PM
  #35
froggy88's Avatar
Haha yes that is what is sounds like! Well I suppose its normal then in M mode?
I wish I never installed this kit now I assume the only way to reverse it is to find a stock valve body from the same year transmission?
Old Jan 7, 2014 | 12:10 AM
  #36
bluedevils95's Avatar
I think your the only one. That bang noise from the guy telling me is that is less slippage in the transmission. I had that problem going on for years when I was stock. When the guy was installing it he saw nothing wrong w/ my transmission
Old Jan 7, 2014 | 06:25 PM
  #37
froggy88's Avatar
Well I spoke to transgo support and the tech there said that there should be no clunking or banging noises at all.
Perhaps our kits have been installed incorrectly?
Does anyone have the install instructions for the kit? I tried searching for them but so far I have not been able to locate them.
Old Jan 7, 2014 | 07:26 PM
  #38
Not by the books but there is an install guide here.
Old Jan 8, 2014 | 02:25 AM
  #39
froggy88's Avatar
EDIT: A PDF install guide is here.
Old Feb 11, 2014 | 11:39 PM
  #40
friedsqrl's Avatar
I have the transgo as well on my Vortech 03 5at. I'm experiencing fast & crisp shifts (Smooth like stock but quicker) when 1>2, 3>4, and 4>5. However 2>3 is touchy: at ~40% throttle it feels like im getting rear ended and a loud clunk when in MM. Also the 2>3 in D mode seems like it happens too soon when ~30% throttle as if it shifts too soon. I had my tuner ride in my car for this and apparently its normal because instead of using the clutch packs more to smooth the shifts, they are happening like "Bam!" instantly engaging.
Old Feb 12, 2014 | 06:16 PM
  #41
froggy88's Avatar
That's exactly what mine is like. I find if I drive the car for say 20min the 2>3 shift seems to be less severe however it's not always the case. I was considering having the vb looked at but I'm not sure I'll bother now.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Terry_G35
Aug 4, 2015 02:38 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
realtalk21
Jul 20, 2015 09:07 AM
