I need an advice
Old Mar 26, 2014 | 11:06 PM
mylo2020's Avatar
I need an advice
So I bought my G35 few weeks ago, now the clutch is slipping, and a need a new one, my question is do I need a new flywheel if replace the clutch? my car has 132XXXmiles
Old Mar 27, 2014 | 12:28 AM
JOKER's Avatar
CLUB MODERATOR
you'll find that out once you pull it off. Normally you can just turn it and put new clutch on it.
By turning I mean taking it to the shop and resurfacing it on a mill.
Old Mar 27, 2014 | 03:27 AM
guitarrocker98's Avatar
Joker is right, but from what I have found out get a larger clutch AND a flywheel. Labors the same since its all taken apart.
Old Mar 27, 2014 | 12:57 PM
DEMoLITIoN's Avatar
I drift my vehicles and I don't have time to have the flywheel resurfaced. I usually go this route:
http://www.z1motorsports.com/350_g35...oducts_id=3439
You do not need to resurface the flywheel or buy a new pressure plate. Throw it in and go!
Old Mar 27, 2014 | 01:08 PM
JOKER's Avatar
CLUB MODERATOR
Fly wheels is essentially brake rotors , when changing clutch plates you do need a new surface in order to avoid premature wear of your clutch.
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
