P0024
Old Apr 16, 2018 | 03:42 PM
Jte1998's Avatar
P0024
Just bought a 05 g35 vq35 rev-up 6mt first it had p1084 and 01078 it was camshaft position sensors on exhaust so I replaced them now it’s popping up p0024 something about exhaust timing advanced thought it was timing solenoid so I replaced that but the codes still popping up and sometimes when you try to start the car it turns over but doesn’t crank it’s like the starter isn’t engaging the flywheel but then if you push the car forward or backwards about 6 inches it starts right up I need help please
Old Apr 16, 2018 | 04:01 PM
telcoman's Avatar
Veteran: Army
Missing tooth on flywheel perhaps?
Inspect!
Telcoman
Old Apr 16, 2018 | 04:26 PM
Jte1998's Avatar
Inspect!
Telcoman
would that cause p0024 to pop up
Old Apr 16, 2018 | 04:31 PM
telcoman's Avatar
Veteran: Army
It would cause the starter to spin and not crank the engine.
Fix that first and see what happens.
Is the vehicle smart enough to throw that code for a start malfunction I don't know but that would be a good place to start
Check the EC chapter in the FSM
Telcoman
Old Apr 16, 2018 | 04:45 PM
Jte1998's Avatar
Telcoman
ok what’s the FSM
Old Apr 16, 2018 | 05:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P0024 is the bank 2 exhaust cam angle not matching what the computer is telling it to do.
Do you have enough oil in the engine?
You might need to replace that cam sensor.
You might need to replace the cam timing actuator.
​​​​​Those are the major culprits.
Old Apr 16, 2018 | 05:46 PM
telcoman's Avatar
Veteran: Army
ok what’s the FSM
Factory Service Manual
Telcoman
Jte1998's Avatar
ive replaced the cam sensor I’ll check the oil when I get home
Old Apr 17, 2018 | 12:29 PM
Jte1998's Avatar
i checked the oil and it’s right dead center of the cross hatched area so I guess I need to add some or is that ok and I’ve already replaced the cam sensor and cam timing solenoid if that’s the same as the cam timing actuator
Old Apr 17, 2018 | 05:41 PM
cleric670's Avatar
BANNED!!!
Yeah the cam actuator is the cam solenoid, it uses oil pressure to advance the timing, when you replaced it did you look inside the little screen on the head to make sure there wasn't debris clogging it? When you replaced the cam sensor did you use an OEM Nissan one?
Yes you need to add a little oil but volume isn't the problem if you're within the high and low mark.
Old Apr 17, 2018 | 05:43 PM
cleric670's Avatar
BANNED!!!
Since these are all computer controlled devices you should also clean up all the grounds, top of the timing chain cover, passenger side of the timing chain cover, below the coolant reservoir, chassis in the battery compartment, battery negative terminal. Use a wire brush on the lug, bolt threads, and the contact point, apply electrical anti-oxidation grease, retorque fasteners.
Old Apr 18, 2018 | 09:03 AM
Jte1998's Avatar
didn’t really think to check that and I replaced the sensors with aftermarket versions but they got the sensor codes off so I guess they’re good
Old Apr 23, 2018 | 05:08 PM
Jte1998's Avatar
update I’ve replaced the crank postion sensor change the oil and filter took the car to Nissan dealership and got them to do the exhaust timing relearn on the car and the code is still there really need someone that has got the code to go away and stay away to help me it comes back on within about 5 miles of clearing the code
Old Aug 14, 2020 | 08:31 PM
Terence Wong's Avatar
2005 Infiniti G35 Sedan RWD automatic
did you ever end up fixing problem for light to turn off?
Old Mar 7, 2021 | 03:20 AM
Jyounya's Avatar
Ivory Pearl G35 Coupe
Did you?
Mnav13
Dec 27, 2018 06:25 PM
Mustafa
Oct 15, 2018 01:29 PM
G_sioudi
Aug 16, 2018 12:41 PM
Eli_popoca98
Jul 24, 2018 06:48 AM
Luisssssssg
Jan 10, 2018 05:32 PM
