P1757 Code not a broken lead
Old Apr 6, 2022 | 11:21 AM
tq28tz@aol.com's Avatar
Coupe
2005 G35x
So have the dreaded P 1757. I removed the valve body and the TCM lead for the all the solenoids were fine. The front wheel speed sensor one had already been soldered. I did make sure it was a good connection. So I replaced the solenoid also put it back together and did not fix it….
Next step is to find a used valve body and tcm. Is the 05 awd specific or will other years work, other than I understand the early ones are separate from the valve body. I see ones that look similar but have extra connections.
Old Apr 9, 2022 | 12:39 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's probably just a bad solenoid, you can replace just that solenoid.
Ant2021
May 30, 2021 08:40 PM
Kyronsk8
Drivetrain
Nov 9, 2020 04:43 PM
Ant2021
Sep 11, 2019 11:55 AM
franz182
Drivetrain
16
Oct 3, 2011 08:22 PM
