Carbon Fiber Drive Shaft
Old Oct 14, 2005 | 12:09 PM
jimmykce1's Avatar
Is there a place I can order a carbon fiber drive shaft of my G35 Sedan??
Old Oct 14, 2005 | 12:49 PM
giddyup69's Avatar
try acpt
Old Oct 14, 2005 | 01:58 PM
Audible Mayhem's Avatar
i thought that the 350z and G35 already had carbon fiber driveshafts
Old Oct 14, 2005 | 02:39 PM
WhiteG35C's Avatar
Only 350z does, G35 doesn't for some reason
Old Oct 15, 2005 | 01:08 PM
EricIsKlumzyee's Avatar
cause we're old farts who drive an over priced altima with no desire to go faster
Old Oct 16, 2005 | 02:24 PM
Alan's Avatar
LOL! nice! i was actualy interested in a new drive shaft too.
Old Oct 16, 2005 | 11:45 PM
cmayer's Avatar
i know that the g has a slightly longer wheel base than the z, but are the driveshafts the same length? can i swap a z one to my g?
Old Oct 17, 2005 | 02:47 AM
xswl0931's Avatar
Unfortunately, because of the longer wheel base, the driveshaft on the G needs to be longer so you can't just swap it, otherwise alot of us would have done that already.
Old Oct 17, 2005 | 03:11 AM
zazaracing's Avatar
Team Transport Member
The z's shaft is not 100% Carbon Fiber is it?
Old Oct 17, 2005 | 08:59 AM
no its not all carbon fiber, pretty much just the shaft part, and i believe ours is made out of some aluminum composite and is not that much heavier, plus a carbon fiber drive shaft for our car would be about 1500 dollars
Old Oct 17, 2005 | 09:19 AM
JDM 350GT's Avatar
holy...
well i think i saw a post regarding CF shaft for our cars.
Old Oct 17, 2005 | 09:37 AM
dofu's Avatar
20 Year Member
What about '05 and up? Are they cf stock?
Old Oct 18, 2005 | 04:45 PM
P_Diddy's Avatar
You may want to look at various other components to reduce driveline power loss, like flywheel, clutch, different gearing for better acceleration, etc.
Old Oct 21, 2005 | 09:55 PM
g35_6gear's Avatar
The 350Z shaft is a single piece unit that is easy to make out of carbon fiber. The G35 sedan and coupe use a 2 piece shaft....much more expensive to make......so it is just a standard steel unit. I had talked to ACPT about a year ago and they said if they were sent a sample drive shaft they can make a copy out of fiber. Big $$$$ though.
Old Nov 11, 2005 | 01:37 PM
ratedxmarcel's Avatar
yea those CF driveshafts are UUUUUUUBER strong according to this guy
