SGP Racing Engine / Tranny Packages
Old Nov 29, 2005 | 04:37 PM
PimpCoupe's Avatar
Could anyone who has done an engine or tranny swap post impressions of the upgrade?
Here is the page from SGP's site: http://store.yahoo.com/sgpracing-store/sgpravqmo.html
I keep thinking about getting one of these packages, and with winter coming the car would be sitting in the garage anyway.
Thanks!
Old Dec 1, 2005 | 12:06 AM
Gman2004's Avatar
I bought this package and I made 543whp at 12.5psi with a greddy tt kit. The car was a freaking beast......although I broke something. I don't know what. The car still runs, but it blows smoke. I shipped the car from Miami to SGP last Monday. It arrived this past Saturday. I should know what happened pretty soon. Anyway SGP has a great reputation and they build awesome motors. I would recommend them.
Upgraded Long Block #3: $7500 + $2000 Core - Good up to 850 Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Old Dec 8, 2005 | 11:11 AM
PimpCoupe's Avatar
HUGE power! That must have been fun. How long before something broke?
Did you ship your car to them the first time as well? Or did you just have them ship you the engine and you did the install?
Thanks! Let me know what they say about the smoke.
Old Dec 8, 2005 | 11:29 AM
Gman2004's Avatar
5000 miles.....1000 break in miles and 4000 extremely hard miles.
I just shipped the motor the first time. I wish I would have just sent car and let them do the whole job from the beginning.
I should know by Monday. They are working on the car this week. I think my problem is due to overheating. I wasn't even driving fast. I was on the highway doing about 70mph. When I looked down at my gauges my temp gauge was past the halfway mark. I shut her down and let her cool down. Everything was fine afterwards, I even took her to 135 mph and no overheating. The next day white smoke.
Old Dec 9, 2005 | 04:21 PM
PimpCoupe's Avatar
Crappy.
I have a similar problem - blowing white smoke as well. I'm loosing 45% compression in 2 cylinders. I think I'm just going to have a local shop rebuild it though. These guys know what they're doing and since I'm in Canada I don't have to worry about all the crap with getting the block across the border twice.
I'm running a procharger with an AA fuel system and eManage. I'm only going to increase the max boost to 10 lbs though. Looks like another good winter project!
Old Dec 17, 2005 | 11:52 PM
PimpCoupe's Avatar
Hey Gman - Any update?
Old Dec 18, 2005 | 08:06 AM
Gman2004's Avatar
The motor was pulled and cylinder #6 was fried. They also found a hose disconnected from the waste gate that caused the car to over boost. The motor was sent to the machine shop to see if any damage was done to the cylinder walls. I won't know until after the new year.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
