What fuse owns the TCS and/or the EBLSD?
Old Aug 18, 2003 | 03:49 PM
suprhulk's Avatar
As I mentioned in a thread last week, after pulling the VDC fuse but not pulling the ABS fuse (both of which are clearly marked), I started hearing what sounded like a relay clicking whenever I brought my G to a stop.
I don't know what is causing this relay to click. The TCS the EBLSD or the ABS.
But since my TCS system does not function at all and since my ABS doesn't function with VDC "Off" or the VDC fuse pulled (see my other threads), I'd like to pull the fuse for this system in addtion to pulling the fuse for the VDC.
I.E. Yet another experiment to try to get my G to behave the way I want rather than the way the engineers want.
Because the TCS/EBLSD fuse is not clearly marked, can someone with an FSM check to see if there is such a fuse and of so, tell me which one it might be?
Thanks.
yosip1115
16
Sep 28, 2015 04:14 PM
2014g35x
Sep 11, 2015 07:53 PM
