Auto tranny manumatic question
Old Feb 16, 2006 | 08:11 PM
ITmenace's Avatar
Smile Auto tranny manumatic question
Fellow G drivers I have a 04 Sedan with an auto tranny. I have been reading that the 04.5+ auto tranny's work differently when in manumatic mode. Basically the new tranny's work more like a true manumatic version then the older versions.
So is there an easy way to upgrade the software? on the older tranny's and where did you get the work done? For those that have done this work is it worth the hassle and what was the cost?
Thanks for any feedback that you can provide.
Old Feb 17, 2006 | 03:05 AM
chenga's Avatar
Take it in to the dealer, and they can reflash your TCU
Old Feb 17, 2006 | 10:07 AM
SI_G35Coupe's Avatar
sedan transmissions get different programming than the coupe ones... from what i remember the sedan trans will NOT hold the gear if you hit the redline.
i don't think you can switch transmission programs with a TCU flash, only upgrade to the most current version for your program (ie you can only load a sedan program, not a coupe one). so, if the newest sedan program has the gear holding, then you can do it i think. someone please correct me if i'm wrong, it's been a long time since i read anything about it.
Old Feb 17, 2006 | 10:22 AM
Godfather's Avatar
R u sure man? I just took my car out today and i was wayy above the Red line for few secs and then the car started slowing down. Ofcourse i didnt do it on purpose i was just checking it out since i had the car for soo long and never drove it.
I do have a 03.5 sedan
Old Feb 17, 2006 | 10:29 AM
trey's wife's Avatar
My horns hold up my halo
On this one I can only speak for the 04.5 and after sedans and not the previous design but the tranny WILL hold the gear as long you leave it there. Now, you will bounce off the rev limiter repeatedly if you do not change gears but it will let you do that as long as you want.
Old Feb 17, 2006 | 10:46 AM
DaveB's Avatar
My 03 will bang off the limiter without shifting. At strip, I consistently bang off the limiter as I hold 3rd past the finish line.
Old Feb 17, 2006 | 12:23 PM
ITmenace's Avatar
When in manumatic mode my sedan will also bang off the rev limiter depending on which gear I selected. However, what I was refering to was that the older sedans manumatic only worked in top gear mode I think. What I mean is even though the display say gear 4 you are not really in 4th gear but possibly gear 1-2-3 depending on your speed. Do the 04.5+ work the same way? Or do the gears and the display actually drop to 1 when you come to a stop. I am not sure if I'm explaining the situation well but hopefully you are getting what I'm saying.
Old Feb 17, 2006 | 12:46 PM
Ok...I was not "getting" that this was what you were asking.
Yes, when I come to a stop my display goes down to 1. When I am driving and using the MM, the display shows whichever gear I put it in. If I bump it up one then the display goes up one, etc. It is on a very base level and manual without a clutch. Now that is a VERY base description but I think it answers your question. If not, let us know and we will (hopefully) clarify it for you.
Old Feb 17, 2006 | 12:50 PM
Jeff92se's Avatar
Red Card Crew
You are correct. Older autos MM = put in 4th,3rd etc.. = what the display shows. But at a stop, the tranny actually shifts to 1, then shifts up to the gear you selected in MM and will hold there until you shift it.
Newer MM = select MM and go to a stop. Tranny autmatically shifts to 1 and shows 1. And will hold 1st until you shift out of 1st. And based on what I've read from the latest reply, it will show all these gears when downshifting/upshifting.
Old Feb 17, 2006 | 02:00 PM
ITmenace's Avatar
Folks thanks for your valuable input. So now the big question, is it easy for me to upgrade the programming on my tranny?
Chenga, stated earlier that I can get my TCU? reflashed? Have people actually done this and what was the cost?
Old Feb 17, 2006 | 02:19 PM
right, what i meant was that older sedans, when you selected say "3"... that would actually give you 1-2-3, so more like a "top gear selector"... whereas in the coupe if you are in 3, you are in 3 and that's it
see if you can shoot a PM to GurgenPB, i believe he has an early 5AT sedan and has done extensive work with the transmission IIRC
Old Feb 18, 2006 | 02:01 AM
Gordgee's Avatar
Administrator
I think Gurgen looked into it back a while ago. I believe he said there was no practical way of upgrading the old one to the new. A tranny re-flash definitely won't do it.
Old Feb 18, 2006 | 02:43 AM
G-AT's Avatar
I have an 06' 5AT, its called rev-matching, and yes it feels a lot more like manual.
Old Feb 18, 2006 | 02:45 AM
G-AT's Avatar
I have 06' 5AT, its called rev-matching. Yes its a lot like manual much better then 03-04 tiptronic. If u have an questions let me know.
