Transmission problems?
Old Feb 24, 2006 | 02:45 AM
traian's Avatar
I have the 6-speed manual and when I start the car, especially in the morning, I sometimes, very briefly, hear a grinding noise (for 1/2 second or so). It doesn't happen all the time, but when I hear it, it's exactly when the engine starts up.
Does anybody else have experienced or heard of this problem ?
Thanks.
Old Feb 24, 2006 | 07:29 AM
clifftrail's Avatar
Clutch rattle. No big deal.
Old Feb 24, 2006 | 01:50 PM
Msedanman's Avatar
O.F. Administrator
VQ's have a timing chain that can dry after sitting overnight and cause a momentary rasping/rattling on startup in the morning. No worries.
C.
Old Feb 24, 2006 | 02:51 PM
drunkin master's Avatar
I have the same noise...sometimes hear it sometimes not. Its normal, i think.
Dealer said the same thing as msedanman.
Old Feb 24, 2006 | 03:12 PM
partyman66's Avatar
C.
Usually timing chains don't make noise though unless the chain guides or tensioners are worn.
Old Feb 27, 2006 | 09:52 PM
addaiaway's Avatar
Grinding Noise
I have it to. I just noticed it this morning. Its pretty loud in first gear at around 2000 rpm also in reverse at around the same rpm. I only have 3850 miles on my car its very strange.
Old Mar 2, 2006 | 02:55 AM
traian's Avatar
Thanks everybody ! I guess it seems to be normal, although I never heard this type of noise on any other stick-shift cars. Plus, it's not happening on a regular basis, it's more the exception rather than the rule .... Interesting !
Addaiaway, I only get this noise right when I turn the key and the engine starts up ... it's not when I'm in reverse or at 2K RPM .... you may have a different problem.
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
Jnm07
Sep 5, 2015 01:16 AM
