FS: MISC OEM Engine Parts
consolidating my engine threads into one since I have a few more items that I have added to the list and updated with the items that have been sold now.
1. OEM Crank Pulley with Bolt ---- $40.00 Shipped
2. AC compressor Bracket ---- $25.00 Shipped
3. OEM Oil Non Revup Pump ---- mileage 38-40k ---- $30.00 Shipped
6. OEM Head Gaskets Brand New --- $60 Shipped OBO
8. OEM Intake Collector -- $70.00 shipped OBO
pics:
1. OEM Crank Pulley with bolt
2. AC Compressor Bracket
3. OEM Non Revup Oil Pump
6. OEM Head Gaskets - 1 set left
8. OEM Intake collector
pics:
sold my Modified coolant pipes that were powdercoated gloss black. I have another set of OEM Pipes but the Passenger side was already cut off and welded in certain areas to adapt to the pathfinder cooling mod.
already sold the pathfinder cooling mod but I have the modified coolant pipes that are designed for it.
I will need to get back to you as they are at my buddies shop and im finalizing another guys order who purchased my other ones. Trying to find simplest and quickest way to get his pipes completed. My old pipes posted above in gloss black need one more pipe cut off and welded shut along with a drivers side pipe to be re-welded since it had small pin hole leaks. Instead of us trying to remove all the powdercoat I am using my other set of coolant pipes I had already started modding that are not powdercoating and selling him basically a fresh set. My gloss black ones will be a fresh set as well its just less time for the buyer to use the non powdercoated set if that makes sense.
sorry chris, but can you explain to me what the pathfinder mod is for? is it something i should have for a bling bay? plan on getting a minor wire tuck. could it be something you can construct for sale?
