DIY: High Clutch? want to lower your clutch engagement point?
Old Sep 21, 2006 | 02:39 PM
slimjim's Avatar
make sure to leave a some leeway (centimeter or more). The clutch engages earlier than you'd think. you can do a easy test by:
1) adjust your clutch
2) pressing clutch in
3) shift into first, shift into neutral (don't release the clutch)
4) shift into first again right away - you will notice there is no resistance, because the synchro has synced up the tranny components
5) shift into neutral, wait 15-30 seconds (we are still pressing the clutch here)
6) shift into first. if you encounter more resistance than in step #4, raise your clutch adjustment.
7) repeat until #6 results in the same feel as #4.
Old Sep 21, 2006 | 07:55 PM
dookiewhat's Avatar
hmmm i adjusted mine and its a tad bit higher than the break pedal... is this okay? or should it be even with the break pedal? i got dizzy from being under there for so long haha. can someone take some pics in comparison of the break and clutch pedal? thanks
Old Sep 21, 2006 | 09:45 PM
jclit's Avatar
It should be higher then the brake pedal, if not the clutch will not be engaging correctly. It should be 3-4 turns.
Old Sep 21, 2006 | 10:11 PM
imalazeeass's Avatar
Originally Posted by driftGT350
wow... it is indeed more fun to drive! the length is almost identical to my brothers s2k's length... to me it gives it more of a sporty feel, quick punches and stuff good stuff!!!!
noob!
Old Sep 21, 2006 | 11:34 PM
dookiewhat's Avatar
yeah i lost count... LOL
Old Sep 22, 2006 | 01:11 AM
driftGT350's Avatar
Originally Posted by imalazeeass
noob!
loser!
Old Sep 24, 2006 | 11:46 AM
chilibowl's Avatar
Ok i tried this adjustment this morning, and I did 3 clockwise turns. It does engage alot earlier, but one thing that scared me was that I was feeling a slight vibration in the floor by my left foot when my foot was even off the clutch. Since the first day, my clutch has always chattered very minimally and it goes away when the clutch is pushed in. After the mod, I pushed my clutch in, and the chattering wasnt going completely away, I was listening to it very carefully, and that told me the clutch wasnt fully disengaged. I put it back to stock cuz it scared me. One thing for sure, the clutch pedal becomes alot softer after the mod. Anyone else have some more cents to throw in?
Old Sep 24, 2006 | 01:19 PM
Ralph0064's Avatar
how long does it take to do this mod?
Old Sep 24, 2006 | 01:36 PM
Msedanman's Avatar
O.F. Administrator
Send a copy to our DIY/FAQ forum.
TNX
C.
Old Feb 12, 2008 | 10:49 AM
hdsupercrewf150's Avatar
I need to try this mod. Ever since I got the car the clutch engagement/feel has been wierd to me.
Old Feb 13, 2008 | 10:48 AM
thechronic's Avatar
i dont understand the advantages of this mod
Old Feb 21, 2008 | 08:51 AM
Roguewolf's Avatar
this mod lowers the engagement point basically you don't have to push the clutch as much as u do with regular clutch which engages pretty high. so this way when u shift u can basically just push it shift and ease it out. instead of pushing, shifting and playing with it that way the car doesn't jump/stall on u... Go look at your car and see where the clutch sits.. and just imagine it a tad lower like as if it was sunken in a bit... quicker shifts basically.
Old Mar 3, 2008 | 02:28 AM
GD-Up's Avatar
How many turns before I should start being concerned about the cruise control not working?
what do I have to do to adjust the cruise control so it does work?
Old Mar 6, 2008 | 08:46 PM
  #30
LightsOut's Avatar
SIETESG
i just did this DIY today. didnt take long at all.
i am very happy with my clutch now. i debated a long time on doing this but gave in after getting tired of pre engaging my clutch at street lights.
i turned mine 1 1/4 turn feels perfect for me.
