Clicking axle fixed!
#168
Me too. Just make sure to place the breaker bar where you're pushing it straight down in order to break it loose. That will keep you from rocking it off the jack stands.
#170
I drove ttrank's car solo
Received 1,487 Likes
on
I'm having that same issue and am stumped. It's coming from the rear driver's side and I have taken apart the brakes, re-greased the axle, checked the cotter pin at the outside end of the axle, and even checked my centercap on that rim thinking it might be the issue. The clicking increases with speed, and stops when I apply the brakes. I've had it in a shop and they couldn't find the issue as well as my efforts with all of the above trying to isolate the problem. I'm left to assume it's the axle itself as I bought a used one about 6 months ago with 32K miles. The thing that confuses me is if it's an axle issue why the noise goes away when I brake. I'm thinking the CV joint in the boot is going dry, but the boot has no rips and isn't leaking grease anywhere. That's why I had to replace that side in the first place.
#171
Hi everyone,
New '06 sedan owner here.
I just recently purchased the car and of course - now noticed the clicking from rear axle. It is also noticeable when turning right (though when turning its more of a scratching type of noise).
Anyways - I plan on doing it this weekend. I read the great write up on my350z.com forum, but so far I was not able to find required new side flange bolts/washers/nuts/pin for a sedan. They only seem to be available for 350Z.
Since these cars are very similar in so many aspects, will the 350Z parts work?
Thanks,
Sobek
Thanks,
Sobek
#172
on
#174
Thanks for the answer! I actually cancelled my order for the bolts.
Some guys on the 350Z forum recommend a method that includes only removing axle bolt and pushing it as far in as possible. This should open enough space to clean and grease contact area.
As a side note.... This is my first serious car (power wise) and I freaking love it! Especially in the rain.
#175
I put my snow tires on my car last Saturday (Dec 10th), and today I noticed the clicking sound when I turn left. I'm certain they're not related, but it's winter and I don't have a garage, so I'm going to let the dealer take care of it. I've got a couple of things they can fix, like the very small oil leak in the front of the engine (I think it's the timing chain cover). Luckily it's all covered by the CPO.
How long can I continue to drive with the clicking? The closest dealer is 150 miles away, but I'll be down there next Friday, so I'd rather wait until then to drop it off.
The only things I'm worried about is whether the oil leak will be inaccurately blamed on my MD spacer, and what kind of tires will be on the loaner. As I said, it's winter, and all seasons just don't cut it around here.
#176
It's all good. Got an appointment on the 23rd, it's OK to drive on until then, and they don't care that I have a plenum spacer. Plus I'm getting a G37x loaner. I asked for an FX50 or an M56x, but their answer was a G37x. That's OK, I've been wanting to check out the new body and new engine anyway.
#178
It's not an axle clicking, it was a piece of stiff wire I must have picked up from the road that got partially tangled around the suspension. At first it only clicked when I turned left, but then started doing it all the time in rhythm with the speed I was going. Popped off the wheel, pulled it out, and the sound went away.
I still might take it in to the dealer. I've got that slight oil leak from the front of the engine, and I can have them go over several TSB's, including checking the valve covers for oil leaks. I may even try to get them to replace my lower engine cover under warranty. It's not my fault they rusted because Infiniti didn't use stainless steel bolts and clips. The timing is just about perfect too. I'll be down there anyway, and they're closed until Tuesday the 27th, so I'll get to drive the G37x loaner for at least 5 days, including several longer trips around Michigan. I've been wanting to drive one anyway. Plus I'm off the week between Xmas and New Years, so I can return it whenever my car is ready.
#179
So just to be clear and potentially close this thread out because the step by step on my350z exists already and with all the comments clarifying any of the misc little stuff that wasn't explicitly photographed or presented in video form in that step by step - really, it's pretty well covered.
But.
Everyone is doing this and not once anywhere (including in the TSB) has anyone said what the adverse effect on the parts involved is supposed to be.
So - what EXACTLY happens to the Axle splines, Cap Bolt, Connecting Bolts, Cotter Pins or anything else related if absolutely NOTHING is ever done to fix the little "tink" noise.
But.
