DIY: Spark plug change
Old Jul 17, 2010 | 05:53 PM
  #136
Vince Bryant's Avatar
Thanks! I'm thinking the sames thing. Just turned 100k miles. its running fine. figured its a good time to change.
Old Jul 17, 2010 | 06:08 PM
  #137
G35 Mass's Avatar
You'll see a difference for sure. I noticed a difference when I replaced my Iridiums with new Iridiums.
Old Jul 18, 2010 | 10:47 PM
  #138
HaTa's Avatar
Im at 115 and Im gonna do some plugs as well.
Old Jul 25, 2010 | 10:26 AM
  #139
miltoda's Avatar
I changed my plugs yesterday. I also removed one of the hoses that is right above cylinder 1 as it made it easier to get the coilpack and plug out. I had no oil in the spark plug tubes thankfully as I was at 69,200 miles so no warranty work for me. I did have one problem while putting all the wire harness bolts into the brackets around the engine. The below picture is of the bracket next to cylinder 2. WHile it looks fine from the pic, the bolt is tight, but there is still quite a bit of play with the bracket.
Can someone confirm I have it on right and also, the top of the bolt is stamped with a '7'? I noticed that one of the bracket bolts had a '6' on it, but it was a mm or so longer so I figured it didn't go there. I should have paid more attention to the bracket bolts as I thought there were all the same.
Thanks for the help!
Old Aug 21, 2010 | 02:58 AM
  #140
Ep Drifter's Avatar
are the pulstar spark plugs worth the money? their like $12 ea.
Old Jan 5, 2011 | 12:51 PM
  #141
42N8one's Avatar
Just thought i'd add for people with the the 07 sedan its a bit different but actually easier, my only problem was i couldn't get my spark plug socket to fit down there to grab the spark plug because the tube surround the plug is too small. anyone else have this problem? i think the the HR and rev up are different in this sense, but someone correct me if i'm wrong
Old Jan 14, 2011 | 07:09 PM
  #142
N8Deezy's Avatar
I did my spark plug change on my g. the brackets are quite easy to remove. that allows for enough play. I would also suggest to stick with the NGK plugs. Not too expensive and they get work very well. The only issue I had is since I'm FI the intercooler piping is almost DIRECTLY in the way to access the last plug/coil pack. I think it's the #6 location. That one kinda stunk to get to. The last shop that worked on it cross threaded the bolt and now I'm going to have to tap that insert, but I won't touch it until next time.
Old Feb 26, 2011 | 01:35 PM
  #143
jersey-G's Avatar
Well I tried to change my spark plugs today. I did the drivers side, but the passenger side is such a PITA that it will have to wait for another weekend. I don't know how everyone is having such an easy time with this.
Old Feb 26, 2011 | 08:00 PM
  #144
N8Deezy's Avatar
Look in the D.I.Y. Section. It's an excellent reference if your g is stock or close to stock. I.e. No FI.
Old Feb 28, 2011 | 12:52 PM
  #145
jimmyc13's Avatar
This is the DIY section, for changing plugs...it's what we've used to do the change on our own. I had no issues, just need to take your time & follow every step.
Old Feb 28, 2011 | 08:42 PM
  #146
N8Deezy's Avatar
Ah, i stand corrected. Let me rephrase then. Check this link: https://g35driver.com/forums/engine-...ug-change.html
This is the beginning of the thread which gives great pictures in regards to doing this job.
Old Mar 19, 2011 | 02:08 AM
  #147
nismor34us's Avatar
Just ordered new NGK plugs. Gonna have a fun install day next week, MREV2, Grounding Kit, and new plugs, probably do oil change at the same time.
Old Mar 19, 2011 | 07:44 PM
  #148
Lucky-G's Avatar
Plugs make a HUGE difference if you're getting higher into the milage range.
Old Mar 19, 2011 | 10:03 PM
  #149
vp-g's Avatar
found oil on one of my plugs but non in the tubes. what does that mean? how did oil get in there?
Old Mar 19, 2011 | 10:13 PM
  #150
vp-g's Avatar
Originally Posted by DrrSeuss
Finally got around to doing mines last night @ 99.3k miles. Found a little bit of oil in cylinder #5 and #6 but no biggie.
Replaced them w/ the NGK Iridiums listed on the first page.
did you have you valve covers replaced? these looked pretty wet with oil.
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
