DIY: Spark plug change
Old Apr 8, 2012 | 09:28 PM
  #196
bythabay's Avatar
Originally Posted by Robin Mains
My husband just changed plugs on our 2004 (new to us) G35. Rough idling, so he thought he cracked the coil. BUT, it looks just fine. Said he also heard a crack like sound, but can't see anything. What might have gone wrong for a first-time inifinity owner not used to the cramped space (and darkness!) in this engine?
Perhaps the coils are not hooked up properly? Which plugs did you put in? are all the hoses plugged back in properly? Perhaps a hose cracked?
If you're in the bay area PM me and I can give you a hand.
Old Apr 9, 2012 | 01:21 PM
  #197
MainStreet's Avatar
Thank you so much! Not sure what the "popping" noise my husband heard was, or if the engine code is related to anything else gone wrong, but he did realize he'd crossed the wires and it is now purring smoothly. Thanks again. We'll get the code checked and cleared for free at Autozone.
Old Aug 5, 2012 | 06:38 PM
  #198
EvilG's Avatar
Hi, I just want to say thank you so much for your post. It has helped me alot when I changed my spark plugs today. The left side was sure a pain lol...but it everything went well and my G is running smooth. Big thanks again!.
Old Aug 8, 2012 | 01:05 AM
  #199
GQue's Avatar
Cool
I have an 04 sedan...what are the top recommendations for new plugs? NGK, Denso, Pulstar, etc? Help a G out...
Old Aug 8, 2012 | 02:07 AM
  #200
EvilG's Avatar
I get NGK iridium, to me they are the best. But thats my opinion.
Old Aug 16, 2012 | 11:52 PM
  #201
That's G's Avatar
Sub'd for a plug change soon. Thanks for the clear write-up!
Old Aug 17, 2012 | 04:07 AM
  #202
Ferrara's Avatar
great job with the DIY. I was going to have the dealer do it but seeing it broken down this is no problem.
Old Aug 30, 2012 | 10:29 PM
  #203
tanko11's Avatar
I replaced my spark plugs with the Iridiums, following the instructions. Now my car is idling very rough and the check engine light has been on for a week now. Does anybody have any ideas on whats going on? I've checked the wires and they are plugged in the proper coils.
Any help will be appreciated.
Thanks
Old Aug 31, 2012 | 12:27 AM
  #204
EvilG's Avatar
did you mess with the throttle body while you installed the plugs? Because when I changed them I took the negative terminal off the battery just in case. Have you try to reset your ECU? Try that first, it might help.
Old Aug 31, 2012 | 01:32 AM
  #205
Plur's Avatar
Thanks!!
Old Aug 31, 2012 | 09:54 AM
  #206
tanko11's Avatar
Yes I stuck a rag in the throttle body and cleaned some grime. And yes, I also disconnected the negative from the battery before I did anything.
Old Aug 31, 2012 | 11:01 AM
  #207
That's G's Avatar
In that case, I would agree with EvilG. A lot of people have had problems after cleaning their throttle body. Before going any further, I would try an ECU and throttle body reset and see if that remedies your situtation before going any further.
There are a lot of threads about people having problems with their throttle bodies after cleaning them. I would also suggest reading some of those threads to see if their problems are similar to yours.
Old Aug 31, 2012 | 03:50 PM
  #208
tanko11's Avatar
So I went to Advance Auto this aftertoon and had them use their code reader, and it says the problem is with the Idle Air Control Valve, which I'm guessing is part of the throttle body.
So I will try your suggestions and reset the ECU.
Now what's the best way to reset the ECU?
I appreciate the help.
Old Aug 31, 2012 | 05:42 PM
  #209
EvilG's Avatar
Hey tanko, if next time you want to clean your throttle body, disconnect your negative terminal and also disconnect the connector on your throttle body to avoid this problem, because I've clean my throttle body before and everything was fine as long as you disconnect the battery and the throttle body connector. As far as resetting the ECU, do this:
Operations Procedures:
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (NOT start) and wait 3 seconds.
2. Fully depress and release the accelerator pedal, kind of hard (5 TIMES!!)
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. If the CEL light continues to remain ON, repeat the above steps. Remember, timing is EXTREMELY critical to resetting the ECU. You may even need someone's help to do this correctly.
Try that and if that doesnt fix your idle issue, you might need to do a throttle body relearning process.
Old Aug 31, 2012 | 10:39 PM
  #210
tanko11's Avatar
Thank you so much EvilG.
I followed the instructions and cleared the CEL. Now I need to do the relearning process like you suggested. I'm searching for instructions now. I'll let you know how I make out tomorrow.
Thanks.
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
