DIY: Plenum Spacer Install Guide (MotorDyne 5/16" Basic and others)
Old Apr 8, 2009 | 07:30 PM
Vrod-Mike's Avatar
In your pics it look like the OEM plenum gasket is still in place under the MD spacer, but Tony says to discard it and it also says that in the instructions. Did you remove it before putting the upper plenum back on?
Old Apr 8, 2009 | 11:01 PM
PTownG's Avatar
no offense to the OP but why do people continue to install spacers on revup engines with the stock lower plenum?
Old Apr 9, 2009 | 02:13 PM
sfgr415's Avatar
According to his sig, he has an 07 5AT, which is the non-revup engine.
Old Apr 11, 2009 | 11:12 AM
blAk mAx's Avatar
nice
Old Apr 21, 2009 | 06:39 PM
All G'd Up's Avatar
How much more is involved to install the iso thermal copper spacer? It says to use this spacer if it snows in your area... I don't drive the G in the snow but I do drive her in the cold weather, is it necessary for me to get the copper spacer kit?
thanks
Old Apr 26, 2009 | 08:14 AM
DJMaffei's Avatar
what if you got a ISO Copper motordyne 5/16 spacer...
Old Apr 26, 2009 | 06:11 PM
Blue Dream's Avatar
I drove ttrank's car solo
The MD instructions say you can replace it or put the MD spacer over it in case you sell the car and want to take it out. Just put mine in today and am quoting directly from the instructions.
Old Apr 26, 2009 | 07:15 PM
fishhouse's Avatar
+1 - my MD instructions say it's you're choice...leave it in or remove. knowing i'd only have mine in for a year or so and then be removing to sell my car, i opted to leave it so i'd know where it is. no problems to date.
Old Apr 29, 2009 | 09:42 PM
abailey362's Avatar
thanks for the write up. will be ordering a spacer soon and will def. use this
Old May 26, 2009 | 08:32 PM
TurboDreamzG's Avatar
How come in the instructions he has on his page he doesn't have anywhere listed where he applied the LOCTITE or put any sealent on the plenum spacer? Aren't you supposed to do that also?
Old May 26, 2009 | 09:22 PM
fishhouse's Avatar
as far as loctite, refer to Step 10. feel free to use it...can't hurt.
MD instructions say to use it and they include a small tube. i've seen some spacers that don't come with any or mention it. whatever makes you happy...not going to be the end of the world if you don't. torque your bolts right and check them again a few months later if you need to.
sealant is new to me. don't recall the MD guide mentioning anything about sealant nor it coming with any. guess the gaskets is sufficient. but again, guess it can't hurt if you feel the need.
Old May 26, 2009 | 10:22 PM
http://www.skunk2.com/installation/307-07-0400.pdf
step one on the last part says they installed sealant but i guess you are right you can use it to ensure proper function but it wont hurt it without it. Anybody else use sealant on here for their spacers?
Old Apr 27, 2010 | 05:11 PM
mckma's Avatar
plenum spacer 2004
I an 04 g35 with an automatic transmission added a z tube with an jwt pop charger nice ,,just put in a basic 5/16 plenum spacer motordyne, here is what i noticed deeper sound when at idle , nice little drone while cruising,, but HP nothin https://g35driver.com/forums/images/...dunno.gifmaybe a little more ummff around 6000 rpms just like the dyno read, if you want a deeper sound cool but for more hp just get the Z tube and jwt pop charger sorry did not get my 200$ worth, just sounds good though , the pop charger and z tube that i could feel
Old May 4, 2010 | 10:20 PM
JJSOLON's Avatar
Great DIY Thanks
Old May 5, 2010 | 05:39 PM
  #30
mckma's Avatar
Originally Posted by JJSOLON
Great DIY Thanks
just reset the throttle body , as recommended by motodyne ,much mure responsive and punchy, but for now i think if i where to do it again i would just go with a ztube and a jwt pop c-
