Would the Utec avoid my G WARRANTY?
Old Jul 1, 2006 | 03:48 AM
GTT's Avatar
GTT
G35 Twin Turbo
Recently I have installed my Utec, and I’m happy with the results. But I’m afraid if I took my car to the next oil change they will avoid my warranty specially that I have to fix things on my car under the warranty such as clutch paddles stick sometimes, rear axils clicking noise, and windows rattle.
It’s really a hard work to take the Utec off. I don’t think they can notice the Utec if I put it on Stock MAP, but I have my Tuner Pro in the Glove box.
What do you guys think?
Old Jul 1, 2006 | 07:42 AM
Down_Shift's Avatar
If it doesn't have anything to do with the ECU the warranty will still be good..
How did you fit your Utec under the dash?
Old Jul 1, 2006 | 08:14 AM
GTT's Avatar
GTT
G35 Twin Turbo
that is how !!
Old Jul 1, 2006 | 01:20 PM
99atlantic's Avatar
I get a kick out of peopel who mod their car then worry about their warranty, LMAO
Too bad the ECU pretty much controls the entire car, heh.
Old Jul 1, 2006 | 07:58 PM
Rookie84's Avatar
Just lock the glovebox when you take it to the stealership I don't think they would notice unless they see the unit.
Old Jul 1, 2006 | 09:35 PM
GTT's Avatar
GTT
G35 Twin Turbo
Dude how did you take the bracket and glovebox out?
On step 1 and 2 there are clips take them off. Put you have to take it easy cause there is a big chance for them to get broken.
I did this for you, i hope it can help. After you take the glove box off, you can work easy on everything. Try to read the Utec manual on how to install the ECU on the Utec. But there is a problem you can’t return the glove box easy after you install the Utec, you will need to cut the back of the glove box. I will post this PM on the thread so everybody can learn.
Old Jul 8, 2006 | 09:34 PM
Dr_jitsu's Avatar
Nice choice of mods, however and MREV2 (u have the rev-up motor, yes) and a spacer would cheaply give you another 15 horses...of course u would have to re-tune
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
yosip1115
16
Sep 28, 2015 04:14 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
